Sum involving reciprocal of binomial coeffients
amind
If $$a_n = \sum_{r=0}^{n} \frac{1}{\binom{n}{r}}$$
Find $$\sum_{r=0}^{n} \frac{r}{\binom{n}{r}}$$ in terms of an and n
2. The attempt at a solution
Let $$f(x) =\sum_{r=0}^{n} \frac{x^r}{\binom{n}{r}}$$
Then, an = f(1).
Observe that f'(1) is the required sum.
I was thinking if I could find an expression for f(x) then I could obtain the required sum, but with no luck.
Other than that I've tried expressing the binomial coefficients in terms of factorials, again in vain. So I am looking for some pointers that don't involve finding an by using Taylor series like I found on Google.
Then, an = f(1).
Hint: notice that ##\displaystyle \frac{r}{\binom{n}{r}}=\frac{r r! (n-r)!}{n!}=\frac{(r+1) r! (n-r)!}{n!}-\frac{1}{\binom{n}{r}}=\frac{(r+1)! (n-r)!}{n!}-\frac{1}{\binom{n}{r}}=\frac{(n+1)(r+1)! (n+1-r-1)!}{(n+1)!}-\frac{1}{\binom{n}{r}}=\frac{n+1}{\binom{n+1}{r+1}}-\frac{1}{\binom{n}{r}}##
Now take the sum for r=0 to r=n and see what it gives.
I got (n+1)*an+1-an-(n+1)
How do I convert an+1 to an ?
I hoped that an expression including ##a_{n+1}## would be acceptable. If not, this is trickier than I thought.
This paper gives a formula for ##a_n## (proof can be found here, the second proof is elementary), and from that you can derive ##a_{n+1}## in terms of ##a_n##. I doubt that this is how this exercise is intended to be solved. There must be an easier way ...
And if you write ##f(r^\frac{1}{r}) = \sum_{r=0}^n \sum_{j=1}^r \frac{1}{C(n,r) }## and exchange the order of summation ? You will have ##f(r^\frac{1}{r})## function of ##a_1,...,a_n## ?
Gotcha, the trick is writing r as n - (n-r) in the first step and then using the property C(n, r) = C (n, n-r)
Likes Samy_A
Nice.
It gives ##\displaystyle \frac{r}{\binom{n}{r}}= \frac{n-(n-r)}{\binom{n}{r}}=\frac{n}{\binom{n}{r}}-\frac{(n-r)}{\binom{n}{n-r}}##, and then taking the sum for r=0 to r=n leads to the result.
Indeed much simpler than actually computing ##a_n##.
