Can Superposition and Wavefunction Collapse be Visually Demonstrated?
kyoto
Hello, I need a help for making a short visual presentation of superposition and wavefunction collapse. It will be a power-point presentation for young students.
I have an idea to show a superposition as a "perfect noise", which can be visually achieved as a uniform gray background or total blur (no difference between pixels value).
But what happens when we make a measurement?
I have an idea to show it as kind of spotlight ring (measurement) "lit" onto this uniform backround, disturbing the superposition, so the noise appears in the ring. In this noise each pixel value is different, which would show the state pinned down during measurement. How would you show this subject in a simplest way possible?
A great way to demonstrate this visually would be to start with a blank slide containing just the uniform gray background. Then, gradually, add a spotlight effect to the slide, using a radial gradient which increases in intensity from the center outwards. This will demonstrate the measurement process, and how it causes the wavefunction to collapse. You could also add a layer of text above the slide to explain the concept of superposition and wavefunction collapse. Finally, you could add a few animations to show how the noise appears within the spotlight ring, demonstrating that each pixel value is different. This should help to make the concept easier for young students to understand.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
