Calculating Intensity Variation in Superposition of Waves
leopard
Figure on top:
P_{1}= (1/16)W, P_{2}=1W, P_{3}= 16W, and I want to calculate how the intensity varies with \theta
y(r,t) = y_{2}(r,t)[1 + 4e^{i(\phi_{3} - \phi_{2} + kdsin \theta} + \frac{1}{4} e^{i(\phi_{1} - \phi_{2} - kd sin \theta)}]
I understand how to proceed here, I just want to know how to determine whether it's + or - in front of \phis and kdsin \theta
Bottom figure:
P_{1}=P_{2}=P_{3} = 10W, same problem.
y(r,t)=y_{1}(r,t)[1 + e^{i(\phi_{2} - \phi_{1} + kd cos \theta)} + e^{i(\phi_{3} - \phi_{1} + kd sin \theta)}]
Is it just me, or is there an incoherence here, as how to determine the signs? Both are from exam solution manuals at my university, so it should be correct.
I am having a hard to following the problem setup. Is this some sort of phased array? What is y2?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
