Supersymmetric Lagrangian Transformation (Grassmann Numbers)
Lonsdale
I've been tasked with showing that a Lagrangian under a set of transformations changes by a time derivative. All has gone well, except I'm left with two remaining terms, that I am completely confident, aren't there by mistake (as the 16 terms that should be expected have all popped out with the correct signs etc).
The two terms, I believe, probably cancel but I don't just want to speculate. Anyway, the two terms that remain are,
W'' W' (ψ^*ε^* + εψ)
where W is the Superpotential (primes representing derivatives, w.r.t x) as a function of the spatial co-ordinate x. ψ represents the Superspace co-ordinate and epsilon represents the small change Grassmann parameter relevant to our transformation. Stars represent complex conjugates.
Now, I will also add that ψ is a Grassmann number so we can rewrite the terms such that,
W'' W' (ψ^*ε^* - ψε)
So, briefly put, do these two terms cancel one another out? If so, why?
(also, please do not delete my post for not following the template, I didn't find it necessary given that this is quite a small scale question)
Thanks for your time, Physics forum!
Ok... after some thought I don't think they can cancel in this way (or the rest of what I have done wouldn't make sense).
Anyway, instead of writing everything out in full, I'm basically working the Lagrangian on page 5 of this source http://www.phys.columbia.edu/~kabat/susy/susyQM.pdf and using the transforms also on the bottom of page 6.
The terms above come from the final term of the Lagrangian, i.e.
ψ^*ψW''
The the 3rd and 7th terms when multiplying out the brackets. As I mentioned before, everything else canceled out in the calculation or was used to show that the change in the Lagrangian is a total time derivative, I was simply left with the aforementioned two terms.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
