The discussion focuses on calculating the total complex power consumed by a load in a three-phase system, emphasizing the need to multiply per-phase values by three to obtain total power. The initial calculations yield a total complex power of 2592W + j3456VAR from the source, while the load's calculated power is 720W + j864VAR, which requires adjustment for the three-phase context. Participants clarify that discrepancies arise due to power associated with line impedance, which must be accounted for in the total power analysis. The load power factor is computed as 0.64 lagging, based on the total active and reactive power. Ultimately, the correct approach involves using the per-phase calculations and adjusting for the three-phase system to determine accurate power values and factors.
