Supplied continuously-Tank Draining Problem
  • Thread starter Thread starter nj_sk
The discussion revolves around a tank continuously filled with water at a rate of 5 L/min, while also draining through a hole at the bottom. The participants emphasize the relationship between the height of the water and the outflow rate, suggesting that a differential equation is necessary to model this dynamic. They note that, intuitively, the inflow and outflow will reach an equilibrium point where the height stabilizes. There is some confusion regarding whether a differential equation is needed, as one participant mentions their professor's differing opinion on the matter. Ultimately, a participant successfully formulates a differential equation to analyze the problem.
nj_sk
OK, here is my problem.
There's a tank, continuously filled by water from top, at 5 L/minute flow rate. The tank has a hole on bottom (at h=0) of it, so water also come out through it. The Area of hole is 1 cm2 and Area of tank is 0.25 m2.
The height of the tank supposed to be very high so water can't out.
The question is about equation h(t), that is height of water in the tank versus time.
My teacher told us to start from Bernoulli's Law, but I'm stuck now...the problem just confused me because there is continuously water supply...
I realized that water flow at the hole is dependent on height of the water, and height is also dependent on time.
Any idea? Please help me. Thanks in advance.
This sounds like a classic problem in differential equations. Like you said, the rate of water flow out the bottom depends on height, and the height depends on the overall water flow which is a combination of the drain and the continuous supply. So write a differential equation that includes all this.
Intuitively, since the tank is very tall, you can imagine that there will be a point where the inflow and outflow rates become equal: the height - and therefore water pressure - becomes large enough so that the outflow approaches 5 L/min, and the tank stops filling. So I would think you're looking for some sort of exponential decay.
Yes, I also think it's a differential problem, but my teacher wasn't. I don't know why he said that we don't need to use differential equation...he's a professor in quantum physic, expert one, so I still confuse about that...is it true that we don't need it? Is it possible?
Still, I can't make a differential equation too...(I am new here, also not so smart in physic, this is not my field actually...)
OK. I have figured it out.
I build a differential equation, solve it using finite difference.
dh/dt = ((2-A2*sqrt(2g*h))/A1
You should check your equation. It's wrong, at least, in the dimensions; but the form looks fine.
Maybe your professor meant, computing a direct integral is not solving a differential equation? :biggrin:
