Surface area problem involving solids of revolution
In summary: I suppose you could call it thickness if you like.The next step I have is S= 2pi * integral of ((9-y)^(1/2)*(sqrt(1+(1)/(4(9-y))) from there the integral turns really ugly for me so I'm assuming I've made a mistake somewhereOK, so you are making progress! You'll get there!I suggest doing the algebra before the calculus. So you have:$$dS=2\pi x ds=2\pi \sqrt{9-y} \sqrt{1 + \frac{1}{4(9-y)}} dy$$Now you can multiply out the square root and integrate:$$dS=2\pi \sqrt{
m0gh
27
Evaluate the definite integral for the surface area generated by revolving the curve about the y-axis:
Curve: y=9-x^2 about y-axis
Attached
When you write out your maths working - also write some, you know, words - so people know what the equations are supposed to be for.
The curve is y=9-x^2, between 0 < y < 9 and you are rotating about the y axis.
It looks like you have applied a formula instead of understanding it.
That leads to uncertainty about the answer.
i.e. could you find the area dA of the strip on the surface between y and y+dy?
Lastly: you have not asked a question - do you have an issue with what you have done?
This information helps us to direct replies to where you need them.
Sorry, my first question would be, is it correct?
If not could you point out the beginning of my mistake.
I can't really tell without doing it myself - it looks like the right formula.
dx/dy is incorrect, but not in a way that will affect the result.
You should also double-check your algebra in simplifying the integrand.
$$\sqrt{9-y}\cdot \sqrt{1+\left(\frac{1}{2}\frac{1}{\sqrt{9-y}}\right)^2}=\left[1+\frac{1}{4}\frac{1}{9-y}\right]^{1/2}\sqrt{9-y}=\cdots$$... how do you take the √(9-y) inside the other square root?
Use a vertical slice. The region is bounded between ##-3 ≤ x ≤ 3##.
##r_{in} = x - dx##
##r_{out} = x##
##r_{ave} = \frac{2x - dx}{2}##
##r_{out} - r_{in} = dx##
##h = 9 - x^2##
So your volume element would be:
##dV = 2\pi*r_{ave}*(wall \space thickness)*height##
Simplify that and ignore any ##(dx)^2## terms.
So your volume element would be:...
... to find surface area?
The vertical slice between x and x+dx is a parabola thickness dx
The area of the parabola would be ##\int y(x,z) dz## with apropriate limits - wouldn't it be easier to slice the resulting parabaloid horizontally or use shells?
Anyway: surface area...
What wrong with summing the areas of the annuli between ##y## and ##y+dy## - which is what OP is doing?
I just found vertical slices to be convenient. You could also write:
##x = ± \sqrt{9 - y}##, ##0 ≤ y ≤ 9## and use horizontal slices.
Surface area though I didn't see that my bad. Thought it was a volume of revolution problem.
... well that's what the title says right? ;)
Well sort of - though it is a solid of revolution problem - the task is not to find the volume of the solid.
There's also a niggle: your formula was for cylinder method - not vertical slices.
These details are worth marks.
But good to see someone else weighing in: if you don't speak up you don't learn stuff.
Okay, I made another attempt at this problem but once I start to take the integral things become very ugly.
This is where I am now. http://www.wolframalpha.com/share/clip?f=d41d8cd98f00b204e9800998ecf8427e51gddpbmno
If someone could tell me if I'm on the right track and if so which way is the best to integrate and if not then I think I need help setting up the problem. I will be active for the next few hours so we can facilitate the discussion.
[Edit] Sorry for using the WolframAlpha tool but I don't know an easier/faster way to post math formulas [/Edit]
Early on in this thread, Simon pointed out that you should include words along with your mathematics to explain what it is that you are doing and/or attempting to do.
None of your subsequent posts do that.
I do apologize. I guess I'm not confident in putting math into words.
I'm trying to follow formulas for similar problems.
I rewrote the problem in terms of x which gave me x=sqrt(9-y)
took the derivative which gave (-1/2)(9-y)^(-1/2)
therefore S=∫2∏x ds
with ds=sqrt(1+(1/4(9-y)))
Can anyone spot a/the mistake?
therefore S=∫2∏x ds
Use a common denominator inside the radical sqrt(1+(1)/(4(9-y)), then combine the two radical expressions into one radical expression.
I think you can integrate that.
You can use LaTeX here:
https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
... is is extremely worthwhile learning this method.
... that's OK, we've all been there. Just give it your best shot and we'll give you pointers.
The only way to get confident is to do it.
... it is better to use maths ;)
$$x=\sqrt{9-y}$$
Reasoning: the distance of the surface from the y-axis is x(y).
therefore S=∫2∏x ds
with ds=sqrt(1+(1/(4(9-y))))
Reasoning: the area of the annulus (the surface ring) between y and y+dy is dS=2\pi x ds where ds is the length, along the surface, between x(y) and x(y+dy).
The total surface area is the sum of all the annuli: $$S=2\pi\int_{S}x\; ds$$
... in this case: ##ds = \sqrt{1+(dx/dy)^2}\; dy##, so you need to differentiate x(y). $$\left(\frac{dx}{dy}\right)^2 = \frac{1}{4}\frac{1}{9-y}$$
$$ S=2\pi\int_0^9 (9-y)^{^{\frac{1}{2}}}\left(1+\frac{1}{4(9-y)}\right)^{\!\!\frac{1}{2}}\;dy$$
... from there the integral turns really ugly for me so I'm assuming I've made a mistake somewhere
... Ugly integrals are normal in real life, though less common in school problems. You've done tricky integrations before, the way forward is to look for a way to simplify it. SammyS suggests:
... a "radical expression" is anything with a square-root symbol.
You also got a nudge in that direction in post #4.
... you should know several techniques for integrating square-root functions.
Thanks everyone for your help with this one. I talked with my professor last night and her first question was why I set it up as [itex] x = \sqrt{9-y} [/itex] She told me to try it again the way it is already set up.
Honestly I did it the first way because it was my intuition and I didn't question it.
Here is the solution I got after she made that suggestion.
[itex] y = 9 - x^2 [/itex]
Taking the derivative:
[itex] f(x)' = -2x [/itex]
Squaring the derivative gives: [itex] 4x^2 [/itex] (for future use)
Set up the Surface Area equation as:
[itex] 2pi \int_0^3 x \sqrt{1 + f(x)'^2}\ dx [/itex]
Take integral with u-substitution:
Let [itex] u = 1 + 4x^2 [/itex] then [itex] du = 8x [/itex]
which gives: [itex] ∏/4 \int_0^3 u^{(1/2)} \ du [/itex]
Integrate: [itex] ∏/4 [{(2/3)} u ^{(3/2)}] = ∏/4 [{(2/3)}(1+4x^2)^{(3/2)}] [/itex] evaluated from [0,3]
Sub in the values: [itex] ∏/4[{(2/3)}(37)^{(3/2)}] = 117.84 [/itex]
This is my first attempt at using the Latex code so please forgive me as parts of it still do not look right. Regardless this is the correct answer. ( At least, according to my professor )
LaTeX use fine - just a tip: to get lower case Greek letters, spell the name without the capital.
So \Pi gets you ##\Pi## while \pi gets you ##\pi##.
For the math - you still sound like you don't really understand what is going on...
It is much better to understand than to memorize equations.
The surface of a solid of revolution has a rotation axis (in this case the y axis) and it has a radius that varies with position along the rotation axis.
Your method starts by working out the area of the annulus between y and y+dy, which, I agree, is more intuitive. The prof's method is to find the area of the annulus between r and r+dr ... (in this case, r=x).
It is the advantage of using polar coordinates.
The equation of the surface is: y(r)=9-r^2
The annulus between r and r+dr has area ##dS=2\pi r \;dl## where ##dl## is the length along the surface between r and r+dr. So $$dl=\sqrt{dr^2 + (y(r+dr)-y(r))^2}\\ \qquad = \sqrt{1+\left(\frac{y(r+dr)-y(r)}{dr}\right)^2}\;dr$$... notice that the remaining squared term inside the radical is the definition of dy/dr ?
Then you get the formula you used above.
In terms of memorized formula - the surface area of a solid of rotaton is: $$S=2\pi\int r\sqrt{dz^2+dr^2}=2\pi\int_z r\sqrt{1+\left(\frac{dr}{dz}\right)^2}\; dz=2\pi\int_r r\sqrt{1+\left(\frac{dz}{dr}\right)^2}\;dr$$ ... where the z-axis is chosen to correspond to the rotation axis, and ##r^2=x^2+y^2## is the distance from z to the surface.
I really appreciate your help with this, Simon.
When you say:
When you say the annulus between y and y+dy I am imagining the small change in the y is accounting for the very small height of the rectangle or rings. This height multiplied by length (2[itex]\pi[/itex]r) accounts for the surface area of one ring? I'm trying to understand the concept so please bare with me if I'm off.
Also when you explain that the prof's method is to find the annulus between r and r+dr I am not able to visualize this. Are the rings still horizontal? The part that says "between r and r+dr" is what I'm not able to see.
When you say:
You are doing fine so far.
Technically each narrow ring is a truncated cone.
The rings conform to the surface of the solid - it's like when you divide the area under a graph into trapeziums rather than bars.
On your graph y=f(x), the two points (x,f(x)) and (x+dx, f(x+dx)) have a "diagonal" line segment between them. The length of this line segment is the "width" of the annulus.
Some people would just say that dy=f(x+dx)-f(x) right off.
I can definitely see the bigger picture now.
The
$$dl=\sqrt{dr^2 + (y(r+dr)-y(r))^2}\\$$
is the length of the line between (x, f(x)) and (x+dx, f(x+dx) from the Pythagorean theorem.
Then using that as the "height" or "width" of the truncated cone and multiplying it by 2##\pi##r then summing up the cones from [0,9] gives you the surface area!
In the equation above, wouldn't $$(y(r+dr)-y(r))$$ give a negative answer? I know it doesn't matter because it will be squared I am just trying to make sure I understand every part of the equation.
The
Well done.
height and width are not good words for this are they - that's why I was careful to call it the "length along the surface" instead. But that's the idea.
If you are summing along the x axis, the limits have to change though.
That is correct - because, for that equation, y decreases with r.
That is perfectly fine and you should have met negative slopes before.
Okay, now I understand this problem and what I learned here has spilled over into other integration problems.
I want to ask though. When you integrate along the x-axis are the rings still in the same position as integrating along the y-axis? When I think about integrating along x my mind automatically turns the rings vertical but then the revolution doesn't work so I'm assuming they stay the same?
It doesn't matter.
It is good discipline to think of them as being in different positions and having different widths.
You can see this if you replace the dx and dy terms with deltas instead.
The line between ##\big(x,y(x)\big)## and ##\big(x+\Delta x, y(x+\Delta x)\big)## is not always going to be the same length as the one between ##\big(x(y),y \big)## and ##\big(x(y+\Delta y),y+\Delta y \big)##
The infinitesimal version comes when you take the limit that the delta-thing gets very small.
... the rings are neither vertical nor horizontal, they are "diagonal".
...what I learned here has spilled over into other integration problems...
... which is why I teach it that way: well done :)
When you get used to the process of setting up the infinitesimals that way, you'll find you no longer need to memorize the formulas and you get more confident with the results.
What is a solid of revolution?
A solid of revolution is a three-dimensional shape that is formed by rotating a two-dimensional shape around an axis. Examples of solids of revolution include cylinders, cones, and spheres.
How is surface area calculated for solids of revolution?
The formula for calculating surface area of a solid of revolution is 2π∫(r(x)√(1+(f'(x))^2)dx, where r(x) is the radius of the shape at a given point and f’(x) is the slope of the shape at that point. This integral is performed over the interval of the shape's rotation.
What are some real-world applications of surface area problems involving solids of revolution?
Surface area problems involving solids of revolution have many practical applications, such as calculating the surface area of a water tank, determining the amount of paint needed to cover a water tower, and finding the surface area of a car tire.
What is the difference between a solid of revolution and a solid of known cross section?
A solid of revolution is formed by rotating a two-dimensional shape around an axis, while a solid of known cross section is created by stacking or combining two-dimensional shapes. The method used to calculate surface area for each type of solid is different.
How does changing the axis of rotation affect the surface area of a solid of revolution?
Changing the axis of rotation can significantly impact the surface area of a solid of revolution. For example, rotating a semicircle around its diameter will result in a larger surface area compared to rotating it around its base. In general, a longer axis of rotation will result in a larger surface area.
