How Do You Determine the Limits for Surface Integrals?
galaxy_twirl
∫∫D F((r(u,v))⋅(ru x rv) dA
[/B]
I got stuck after finding the above, at where the double integrals are. :(
May I know how do I find the limits of this? (I always have trouble finding the limits to sub into the integrals. ><)
Thank you! :)
You have chosen u = x and v = y. This is just like a problem you posted earlier. Draw a picture of the slanted plane in the first octant and use the triangle in the xy plane for your limits.
[Edit, added] One thing that may be causing you confusion is the use of ##u,v## parameters when they are unnecessary. You usually use those when there is a reason to change coordinate systems. In a problem like this, ##x## and ##y## are natural parameters and there is no need to use ##u## and ##v##. Just let ##x=x,~y=y,~z= 2-2x-y## and$$r(x,y)=\langle x,y,2-2x-y\rangle$$and look in the ##xy## plane for the limits.
Likes galaxy_twirl
Oh dear! Haha. I didn't realize that this question is similar to the one I have asked earlier. I am currently focusing on past year papers as my Maths exam is just 2 days away. Sigh~ I find that I always have a problem visualising the domain... because I didn't know the domain was a triangle until you told me above and after doing some look-up on Google. >< Sheesh. :(
I will take note of what you have said and try again. :) I will post back here again!
A linear equation in three variables represents a plane.
The given equation ##z = 2 - 2x - y## is a plane. Another example would be ##x + y - z = 1 \Rightarrow z = x + y - 1##.
If you want to have an easier time visualizing, then you can easily solve for the intersections. Consider the points ##(x, 0, 0), (0, y, 0), (0, 0, z)## for the plane equation in your problem.
Choosing the point ##(x, 0, 0)##, you would get ##z = 2 - 2x - y \Rightarrow x = 1##. In a similar fashion you would get ##y = 2## and ##z = 2##. Plotting these solutions on a 3D graph and connecting the dots will give you a nice visual of the plane.
This will also help you visualize the projection of the plane onto the x-y plane. Drawing this projection in the x-y plane will give you your limits for integrals.
Likes galaxy_twirl
I see. Thank you. My teacher changes them to r(u,v) for the chapter of surface integrals, hence I would always change it to r(u,v), though I don't know why my teacher uses the u,v coordinate system. I think I should ask him some day. Haha.
Ah yes, I got the triangle in the xy-plane as shown below:
Just wondering, how can I be very sure that I have placed the limits on my ∫ ∫ correctly? My integral equation is below:
Thank you! :)
Thanks, Zondrina! Your method is really effective! :DI think I can now at least find the intersection points of the lines on the x-y-z axes, though I feel it can be quite difficult to plot/sketch/draw a 3D figure on a 2D piece of paper.
Thank you! :)
Your limits are OK but I think you have u and v exchanged in the integrand. Another reason not to use u and v unnecessarily.
I tried integrating the above and I got the same answer as my teacher, who did it in another way:
Hence, I think both methods work (or is this my method a 'fluke'? Haha.) Thanks. :)
No you didn't. In post #7 you wrote the integrand as ##u-v+2##, which has the ##u## and ##v## switched as I said. Below you have the correct integrand.
I see. Haha. I think I misinterpreted your intended message. Sorry. Thanks for all your help! :D
