Surface of recolution of a curve integrating wrong :-(
darkwolfe5
the curve y= sqrt(x² +1) , 0 ≤ x ≤ sqrt(2) is revolved about the x-axis to generate a surface. Find the area of the surface of revolution.
A = 2π ∫ f (x) * sqrt[1+f ' (x)] dx
I've gotten down to 2π ∫ sqrt(2x²+1) dx
and I know that's correct thus far (confirmed using my calculator)
calc says: 13.14153998
but once I integrate, I get 2π[ ⅔ * (2x²+1)^(3/2) with the limits from 0 to sqrt(2)
Once I substitute the sqrt(2) I get something way out of the park.
calc says: 46.832...
Did I do my integration right?
You can check if it's right by differentiating. After you have checked and seen that it's not, the easiest way forward is to switch variables to polar coordinates.
We haven't gotten to polar coordinates yet...that's what we're supposed to start on Monday :-(
Oops, I mean hyperbolic coordinates (that probably doesn't help, but still :)
well I've had someone on another site tell me:
<quote>
∫ √( 2x² + 1 ) dx
= √2* ∫ √( x² + 0.5 ) dx
= √2* { (x/2)*√( x² + .5) + (0.5/2)*ln [ x + √( x² + 0.5) ] } between x = 0 and x = √2.
</quote>
But that doesn't seem to calculate right to me either.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
