Sweets in a bag probability problem
The discussion revolves around a probability problem involving the removal of sweets from a bag. Participants are trying to determine how many red sweets were initially in the bag based on the probability that the third sweet drawn is red, expressed as (x/2) - 1. The scope includes mathematical reasoning and exploratory problem-solving.
  • Andrei presents a problem involving the probability of drawing a red sweet after removing two sweets from a bag of x sweets.
  • Some participants question whether the expression (x/2) - 1 can represent a valid probability, suggesting that x must be constrained to ensure the result is between 0 and 1.
  • One participant proposes that for the probability to be valid, x must be between 2 and 4, leading to further exploration of cases for x = 3 and x = 4.
  • Another participant argues that if x = 2, there would be no sweets left for the third draw, which contradicts the problem statement that a third sweet is drawn.
  • There is a discussion about the implications of drawing sweets and how the conditions affect the probability of the third sweet being red, with some suggesting that all sweets must be red if x = 4.
  • Participants express uncertainty about the validity of certain cases and the implications of the probability condition given the number of sweets drawn.
Participants do not reach a consensus on the validity of certain values of x or the implications of the probability condition. Multiple competing views remain regarding the interpretation of the problem and the possible values for the number of red sweets.
Participants highlight limitations in the problem's formulation, particularly regarding the conditions under which the probability can be valid and the implications of drawing sweets without replacement.
thebosonbreaker
Andrei has a bag of x sweets.
He removes two sweets from the bag simultaneously (without replacement).
He now removes a third sweet.
The probability that the third sweet is red is (x/2) - 1.
How many red sweets were in Andrei's bag to begin with?
Could somebody please tell me if (and how) it is possible to solve this problem?
Thank you very much for your help in advance!
I am not sure if probability, is the correct term to use here (a probability is a number less than 1, like 1/2 or 1/3). Could the value (x/2) -1 be a number between 0 and 1? If probability is the word that they intend, then Well yes if x/2 is between 1 and 2. What does this tell you about possible values of x? Would it help you to determine how many start out as red? Do they give you any information about the original sweets, which were pulled? You will need to know if they were red, or not.
I agree with @scottdave, the problem does not seem to make sense; what if x=10 so that x/2-1 =4 , or x >10? Are you sure you there isn't a mistake somewhere?
I think, we have to deduce that 0≤x/2-1≤1. ⇒2≤x≤4. Again three sweets are already drawn⇒3≤x≤4. Now consider Case1: x=3. Therefore, prob of third being sweet is red is either 0 or 1 (according as last sweet left in box non red or red after withdrawal of 1st two). This does not satisfy the given prob condition as the given prob=1/2. Alternatively, there are 3 possible cases of the 1st drawn 2 sweets 3C2. That can not produce prob for the last one left=1/2. Case2: x=4. ⇒x/2-1=1.Last two in the box must be red. Therefore the 1st two must also be red. ⇒ all the 4 sweets must be red. Since, if there is one non red, and two reds are drawn in first draw, the prob of red in third draw is 1/2 which does not satisfy the given prob condition. Similarly, there can not be 2 or 3 non reds.
One trivial case remains for x=2. After the 1st two drawn there will none for the third draw. Therefore the prob of red in 3rd draw is 0, which satisfies the prob condition. Then there can be 0,1,2 possible reds.
ssd said:
...One trivial case remains for x=2. After the 1st two drawn there will none for the third draw. Therefore the prob of red in 3rd draw is 0, which satisfies the prob condition. Then there can be 0,1,2 possible reds.
Nice working through. After reading this, and re-reading the problem, I say that x=2 is not a possibility, because the problem tells you that a 3rd piece is removed. This makes it only one possible answer.
Actually, I added the case of x=2 on the basis of the given prob condition (third item is red with prob x/2-1=0). A non existent item (here, the third sweet) can as well be drawn with prob=0 (which, in turn implies, it is impossible to draw it).
  • · Replies 18 ·
  • · Replies 131 ·
14K
