Switch on a transformer but with no load connected
Switching on a transformer without a load connected to the secondary will not cause it to burn, as it operates cooler without a load, provided the voltage remains the same. In this state, the transformer acts as an inductance, with current influenced by supply voltage, frequency, and primary winding characteristics. Appliances often keep the primary connected to mains, which can waste power and expose the primary to voltage surges. The discussion also highlights that voltage transformers are designed for specific frequencies, making them unsuitable for variable outputs like those from wind turbine alternators. Proper safety precautions are emphasized when working with hazardous voltages.
jxlee
If i switch on a transformer but with no load connected to the secondary path.Is the transformer will burn?
No. If the voltage is the same as the transformer normally gets, it should run cooler than if it had a load on the secondary.
A transformer without a load on the secondary is just an inductance. So, the current in this is determined by the supply voltage, the frequency and the inductance and resistance of the primary winding.
Many appliances switch power in the secondary circuit so that the primary is always connected to the mains. This does waste some power (compared with turning off the primary) and it also leaves the primary vulnerable to mains voltage surges.
Yes, if it is a current transformer.
NO, if it is a voltage transformer.
Please inform me if you need more explanation.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
If you are unfamiliar with transformers, I recommend that you do your learning and experimentation with low voltages, like 24V ac. Please do not work with 115V ac until you acquire sufficient education/experience. One mistake could be the last. I've been an EE for 32 yrs., and I never work on 115V ac alone in the lab. I always use one hand when handling hazardous voltages.
Please heed my advice. The ac power mains are not to be taken lightly.
Claude
I am trying to get help with rewiring an alternator for wind power generation is there any help here?
Here is a site that built an alternator for a wind turbine.
http://www.fieldlines.com/story/2009/4/4/214533/4539
Voltage transformers are for a specific frequency. The output frequency of a wind turbine alternator varies all over the place, so don't try to use a transformer. Automotive alternators have a wound rotor with radial field lines, and the stator coil is outside the rotor. The rotor has slip rings for regulating the current. Thw wind turbine alternators have permanent magnet rotors with an axial field, and cannot be regulated. I hope this helps.
Bob S
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
