System of linear equations with alpha variable
literacola
For which value of alpha does the following system of linear equations have a solution?
x + y = 2
x +αy = -1
αx + y = 1
I put it into a matrix that looks like this:
1 1 | 2
1 α | -1
α 1 | 1
Then I subtracted row1 from row2 and it made the matrix look like:
1 1 | 2
0 (α-1) | -1
α 1 | 1
Then I took the 2nd row as α -1 = -1 and solved α to be zero. So, does this mean that the solution for this is all numbers α such that α is not equal to zero?
1 1 | 2
1 α | -1
α 1 | 1
1 1 | 2
0 (α-1) | -1
α 1 | 1
First, when you subtract the first row from the second you get
\left[\begin{array}{cc|c} 1 & 1 & 2 \\ 0 & \alpha-1 & -3 \\ \alpha & 1 & 1 \end{array}\right]Second, your second row tell you (\alpha-1)y=-3, not (\alpha-1)=-3
No.
Cool, thanks! So what's the next step? Not sure where to go from here...
Can I get a hint?
I think the easiest method is to simply say that if (\alpha-1)y=-3, then y=\frac{3}{1-\alpha} and substitute that into any of your 3 equations, solve for x and sub those into the remaining equations to get an equation for \alpha.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
