Tangent line approximations with trig. functions
Jacobpm64
Find the equations of the tangent lines to the graph of f(x) = \sin x at x = 0 and at x = \frac{ \pi }{3}. Use each tangent line to approximate \sin( \frac{ \pi }{6} ). Would you expect these results to be equally accurate, since they are taken equally far away from x = \frac{ \pi }{6} but on opposite sides? If the accuracy is different, can you account for the difference?
Here are my attempts:
Well, first let's find the equations of the tangent lines.
f(0) = \sin (0) = 0
f(\frac{ \pi }{3}) = \sin( \frac{ \pi }{3}) = \frac{\sqrt{3}}{2}
f'(x) = \cos (x)
f'(0) = \cos (0) = 1
f'(\frac{ \pi }{3}) = \cos( \frac{ \pi }{3}) = \frac{1}{2}
So we have (0,0), m = 1.
y = x <---- tangent line at x = 0.
And we have (\frac{ \pi }{3} , \frac{ \sqrt{3}}{2}) , m = \frac{1}{2}
y = \frac{1}{2} x + \frac{3\sqrt{3} - \pi}{6} <---- tangent line at x = \frac{ \pi }{3}
Now we'll use the tangent lines to approximate \sin( \frac{ \pi }{6}).
Using y = x.
y(\frac{ \pi }{6}) = \frac{ \pi }{6} \approx 0.5236
Using y = \frac{1}{2} x + \frac{3\sqrt{3} - \pi}{6}
y(\frac{ \pi }{6}) = \frac{ \sqrt{3} }{2} - \frac{ \pi }{12} \approx 0.6042
They are obviously different. I don't know why they are different though.
Thanks in advance.
L(x) = f(a) +f&#039;(a)(x-a). Think about the graph of the sine function. The linear approximation of \sin x at a = 0 is \sin x \approx x. Also the tangent line approximations are taken from opposite sides of \sin \frac{\pi}{6}. So, its similar to the squeeze theorem. One approximation will overestimate the true value, and another approximation will underestimate the true value.
well, the thing that bothers me, is you said that one approximation should be an underestimate and one should be an overestimate.
the true value of \sin( \frac{ \pi }{6}) = \frac{1}{2}
1/2 is not between our two approximations.
ah yes my mistake. I think the key reason is the difference between the areas of approximation (i.e. 0 and \frac{\pi}{6})
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
