Tangent Properties Symmetry, domain, asymptotes, zeroes
The discussion revolves around analyzing the function y = -2tan(3x + π) + 3, focusing on its period, y-intercept, range, domain, symmetry, vertical asymptotes, and zeros. Key points include the established period of π/3 and y-intercept of 3, while the domain is defined by the values of x that avoid vertical asymptotes, specifically where tan(3x + π) is undefined. Participants emphasize the importance of understanding how to find vertical asymptotes and zeros by solving the equation -2tan(3x + π) + 3 = 0. Additionally, symmetry can be determined from the graph or the property tan(-x) = -tan(x). Overall, the conversation highlights the need for a solid grasp of trigonometric functions to analyze the given equation effectively.
aisha
y=-2\tan (3x+\pi) +3
state the following
period = \frac {\pi} {3}
y-intercept=3
Range = {y: yER}
Domain= {x: ?}
Symmetry?
Vertical Asymptotes?
Zeros?
Can someone please tell me how to figure out what is left there are so many zeroes and i can't read them off of my graphing calculator and same with vertical asymptotes aren't zeroes and this the same thing? I'm a little confused can someone please help me out? I am not sure how to find symmetry either .
https://www.physicsforums.com/showthread.php?t=28
Peope here won't do your homework for you. If you can prove to someone you gave the problem decent effort before coming here for help then maybe someone will POINT YOU IN THE RIGHT DIRECTION but not solve it for you.
That's just a little bit harsh- The original post DID include answers to the the first part of the problem- period, y-intercept, range.
Aisha- the "domain" is the set of all x values for which the function CAN be calculated. The basic function here is tan(x). For what values of x is it NOT possible for find tan(x)? Looking at a graph of y= tan(x) in your textbook might help you see that.
Symmetry should be obvious from a graph- or from the fact that tan(-x)= ?
Vertical asymptotes- closely associated with the problem of finding the domain! Look at graph- perhaps using a large "window".
zeros- where is y=-2\tan (3x+\pi) +3= 0? Solve the equation!
ok i still don't think I get symmetry but for the range I've got
{x: x cannot = -90,90,270,...,XER}
this is from tan(theta) not from the equation I wrote in the first post.
If i look at that equation on my graphing calculator i get
{x: x cannot= 0.47, 1.53, -3.76, -4.80.. XER}
the vertical asymptotes will be the same numbers I assume
Please help me out a little more thanks
im not sure how to solve the equation equal to zero
Aisha- did you notice that \pi[/tex] in your function? When trig functions are used as <b>functions</b>, rather than to solve problems about right triangles, the argument is <b>always</b> in radians, not degrees! <br /> <br /> tan(x) is not defined (and so the domain does not include) \frac{\pi}{2}[/tex], -\frac{\pi}{2}, or generally any odd multiple of \frac{\pi}{2}[/tex]- that is, any number that can be written (2n+1)\frac{\pi}{2} where n represents any integer.&amp;lt;br /&amp;gt; However, your function involves tan(3x+\pi)[/tex]. For what values of x is 3x+\pi= (2n+1)\frac{\pi}{2}?&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; Of course, you can solve -2\tan (3x+\pi) +3 = 0!&amp;amp;lt;br /&amp;amp;gt; That&amp;amp;amp;#039;s the same as saying tan(3x+\pi)= \frac{3}{2}.&amp;amp;lt;br /&amp;amp;gt; Can you find \theta so that tan(\theta)= \frac{3}{2}?&amp;amp;lt;br /&amp;amp;gt; You might need to use a calculator for that. Be sure to put it in radian mode!&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; Once you found that \theta, finish by finding x so that 3x+\pi= \theta.
sry when I posted that I was having a bad day... sry to take it out on all of you guys
15K
