Tangential Component of Centrifugal Acceleration
The discussion centers on the tangential component of centrifugal acceleration as described in Taylor's text. The confusion arises regarding the angle between the centrifugal force and the gravitational force, specifically the relationship between angles θ and latitude L. It is clarified that θ is the complement of latitude, and the tangential component of centrifugal acceleration is derived from the equations provided. A sketch was shared to illustrate the problem, leading to the realization that the angles in the diagram were misidentified. Ultimately, the participants reached a consensus on the geometric relationships involved, resolving the misunderstanding.
SebastianRM
The thing is in page p.347 Taylor, it is said that the component is:
g_tan = Omega^2*Rsin(theta)cos(theta) However the angle between the centrifugal Force and the axis normal to the direction of the grav Force is actually 90 - theta, I am not really getting where I am going wrong understanding this.
The angle in question is between the perpendicular to the Earth's axis (the direction of the centrifugal force component) and a tangent to the surface. That angle is θ which you can see by geometry. θ is the complement of the angle of latitude, L (θ = 90-L).
The magnitude of the centrifugal acceleration (see equation 9.43) is: acf = Ω2Rsinθ. So the tangential component is acfcosθ. At the equator, where θ is 90° (L=0), the centrifugal force is maximum (sinθ = 1) but the tangential component is 0 because it is all in the radial direction (cosθ = 0). Towards the pole, the direction is almost tangential (cosθ=1) but the magnitude of the centrifugal force approaches 0 (sinθ = 0).
AM
Likes SebastianRM
kuruman said:
I thought I explained that to you here.
https://www.physicsforums.com/threads/what-is-the-tangential-component-taylor-p-347.965665/
If there is something you still did not understand, you should have responded there instead of starting a new thread. In any case, post a drawing of what you think is the case. I suspect you have misidentified something.
Sorry about that, I could not track the post I had done already. Here is the sketch of how I am working it out on my mind.
spbCzfS
https://imgur.com/spbCzfS
Since he says: 'the tangential component of g (the component normal to the true grav force)'
spbCzfS
In the drawing you have provided, you have shown two angles of 90-θ making up a right angle! The angle between the Fcf vector and the tangent is 90 - (90-θ) = θ! (the angle of the tangent to the radial vector being necessarily a right angle).
AM
Likes SebastianRM
To supplement post #5 by @Andrew Mason, it is known from geometry that two angles that have their sides mutually perpendicular are equal. In your diagram, the z-axis (along Ω) is perpendicular to Fcf and the radial vector is perpendicular to the tangential component (not shown). Therefore the angle that you show as θ is equal to the angle formed by Fcf and the tangential direction.
Likes SebastianRM
Thank you so much guys! I see it now!
Likes kuruman
  • · Replies 17 ·
  • · Replies 43 ·
11K
