Understanding Changes in Tap Water pH Over Time
  • Thread starter Thread starter caliban07
    Ph Time Water
The discussion centers on the factors influencing the pH of tap water when left to sit. Carbon dioxide (CO2) plays a significant role, as it can either dissolve in water or escape into the air, affecting pH levels. The concentration of CO2 in the surrounding environment and the presence of surface agitation, such as air flow or waterfalls, can enhance gas exchange and influence pH changes. Chlorine, while it can slightly acidify water by forming hydrochloric acid (HCl) and hypochlorous acid (HOCl), has a minimal impact on pH compared to CO2 due to its lower concentrations in tap water. Temperature also affects gas transfer rates; warmer water can facilitate quicker equilibrium but complicates the prediction of pH changes over time, as reaching equilibrium and the rate of change are influenced by temperature.
caliban07
Why does tap water ph rise or decline after it has been set aside for a period of time.
I've heard that Co2 or chlorine 'gas off' and the result in loss if CO2 can raise ph?
Chemistry news on Phys.org
Both are definitely a factor here.
Carbon dioxide can work both ways - depending on the concentration of CO2 in the air near the water source and and in your house it can either leave the water, or dissolve, changing pH up or down.
I suppose the rate in which it changed would also depend on whether there was surface agitation provided by some kind of air flow or water fall which would break the surface enabling better/easier gas transfer?
What part does chlorine play? I've tried to seek explanations online but have been unsuccessful so far.
Definitely.
It should slightly acidify the solution, as it reacts with water producing two acid - HCl and HOCl. But chlorine concentrations in tap water are orders of magnitude lower than concentrations of carbon dioxide, so in most applications their effect on pH can be ignored.
What about the temperature of the water? Would that have an effect on the way the gas is transferred ie does warmer water have a better gas transfer at the surface that would change ph faster or change the ph all together?
I'm only talking warm in the region of 26-30 degrees C
There are two different things here.
One, is what is happening at the equilibrium, the other is how fast we get to that equilibrium. Both depend on the temperature.
Note, that is much easier to calculate equilibrium (final) pH, that to predict pH changes in time (transport phenomena can get incredibly complicated even in what looks like a simple case).
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
