Can I Make My Own 8 Telescope with These Required Instruments?
In summary, the materials needed to make a telescope include a primary mirror, secondary mirror, eyepiece, telescope tube, mounting and support structures, and various tools for construction. The process for grinding and polishing a telescope mirror involves using a flat tool, called a lap, with a grinding compound to shape the mirror to its desired curvature. Collimation is the process of aligning the optical components of a telescope, which can be done with the help of a laser collimator or with collimation tools and instructions. For beginners, a refracting telescope is often recommended, but the best type of telescope ultimately depends on individual interests and needs. It is possible to make a telescope without any prior experience with the availability of resources and guidance.
Harshil
hello ,
any one give me an information that how i make my own 8" telescope...And for making telescope which instuments are require
Astronomy news on Phys.org
There are several good web sites. Try a search on amateur telescope making -ATM.
"How to make a telescope" by Jean Texereau would be a good place to start as far as books go. I found a used copy online for $3. I am assuming you are interested in making a 8" reflector rather than a refractor.
ya i try to make a reflactor
1. What materials are needed to make a telescope?
The materials needed to make a telescope include a primary mirror, secondary mirror, eyepiece, telescope tube, mounting and support structures, and various tools for construction.
2. What is the process for grinding and polishing a telescope mirror?
The process for grinding and polishing a telescope mirror involves using a flat tool, called a lap, with a grinding compound to shape the mirror to its desired curvature. This is followed by polishing the mirror with a finer abrasive compound to smooth out any imperfections. The process is repeated until the desired level of precision is achieved.
3. How do you collimate a telescope?
Collimation is the process of aligning the optical components of a telescope to ensure that light passes through the center of each component. This is typically done by adjusting the position of the secondary mirror and the alignment of the eyepiece. Many telescopes come with collimation tools and instructions, or it can be done with the help of a laser collimator.
4. What type of telescope is best for beginners?
For beginners, a refracting telescope is often recommended as it is easy to use and maintain. Refracting telescopes use lenses to gather and focus light, providing clear images without the need for frequent adjustments. However, the best type of telescope for a beginner ultimately depends on their individual interests and needs.
5. Can I make a telescope without any prior experience?
Yes, it is possible to make a telescope without any prior experience. There are many resources available online and in books that provide step-by-step instructions for telescope making. However, it may require patience and dedication to achieve the desired results. Alternatively, one can also purchase a telescope kit or seek guidance from experienced telescope makers.
  • Astronomy and Astrophysics
