Tell me the fourmla for displacement
  • Thread starter Thread starter killer22
    Displacement
To calculate displacement, additional information such as time and acceleration is necessary. The formulas for displacement include s = ut + (1/2)at² and v² = u² + 2as, where s is displacement, u is initial velocity, t is time, and a is acceleration. Given the initial velocity of 0 and a final velocity of -2, the displacement is likely negative, indicating movement in the opposite direction. Without knowing the acceleration or time, an accurate displacement cannot be determined. Thus, more data is required to solve the problem effectively.
killer22
okay i have a question.
if a squirrel is at 0 on inital velocity and then is at -2 at final velocity.then what is its displacement?
And i would appreciate it if someone can tell me the fourmla for displacement.:smile:
you need to give a lot more info to be able to do this problem
disp= x_o+v_0*t+1/2at^2
I think you would have a negative displacement you instead of going forwards went backwards your displacement would be 2. I think I have problems with physics so...
Like mathmike said, you need to give a lot more information so an accurate displacement can be given, unless you are searching for displacement as a function of acceleration/time etc.
Using:
s=ut+\frac{1}{2}at^{2} (1)
or
v^{2}=u^{2}+2as
Hence, s=\frac{v^{2}-u^{2}}{2a} (2)
where,
s=displacement
u=initial velocity
t=time
a=acceleration
Using the information you have given, formula (1) can be simplified to:
s=\frac{1}{2}at^{2}
and formula (2) can be simplified to:
s=\frac{2}{a}
It is obvious you will at least need acceleration to find the displacement, and yes, the displacement will be negative since your final velocity (v) is negative.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
