Temperature analog of free energy
The discussion focuses on the Gibbs energy, which indicates spontaneity in thermodynamic processes at constant pressure, and the Helmholtz energy, applicable under constant volume. A query arises about an energy measure for spontaneity at constant temperature, leading to suggestions to explore the concept of chemical potential. The chemical potential is identified as related to the partial molar Gibbs energy in multi-component systems. The conversation concludes by clarifying that Gibbs energy is minimized at constant pressure and temperature, while Helmholtz energy is minimized at constant volume and temperature.
Bipolarity
The Gibbs energy is used to determine the spontaneity of a thermodynamic process under isobaric conditions.
The Helmholtz energy is used to determine the spontaneity of a thermodynamic process under isovolumetric conditions.
I was curious: is there an energy used to determine the spontaneity of a thermodynamic process under isothermal conditions?
Thanks.
BiP
Science news on Phys.org
I suggest you look up
'The Chemical Potential'
Google has lots of references.
Isn't the chemical potential just equal to the partial molar Gibbs energy of a multi-component system? How is that related to my question?
BiP
Well, Gibbs energy is minimal under constant pressure AND temperature, and Helmholtz under constant volume and temperature. So, there...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
