Temperature loss - is it correct?
  • Thread starter Thread starter rammer
    Loss Temperature
The phrase "loss of temperature" is considered incorrect in technical contexts, as it more accurately refers to "loss of heat." The term "decrease in temperature" is preferred for clarity and precision. Additionally, "loss of temperature control" may be appropriate depending on the situation. The consensus among participants is to use "decrease" to convey the intended meaning effectively. Clear terminology is essential in engineering and scientific communication.
rammer
Hi, is physically correct to say "loss of temperature"? Doesn't the "loss" relate just to "heat"?
Science news on Phys.org
"Loss of temperature" is indeed an odd phrase, one I wouldn't expect from a native-English-speaking engineer or scientist. If I were editing the text, I'd change it to "decrease in temperature" or "loss of temperature control," depending on the context.
I would go with "decrease"
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
