sona1177
- 171
- 1
Before starting out on a long drive, you check the air in your tires to make sure they are properly inflated. The pressure gauge reads 214 kPa and the temperature is 15 degrees celsius. After a few hours of highway driving, you stop and check the pressure again. Now the gauge reads 241 kPa. a) What is the temperature of the air in the tires now? b) Suppose you now (unwisely) decide to bleed air from the tires. If you let out enough air so that the pressure returns to 214 kPa, what percentage of the air molecules did you let out of the tires? c) What is the gauge pressure after the tires cool back to 15 degrees celsius?
I figured parts a and b out. I am little confused what they mean in part c because isn't the pressure gauge at 15 degrees celsius 214 kPa? The answer is 189 kPa but I don't know why. Thanks.
