Vector Decomposition and Trig in Tension Force Analysis
In the discussion on vector decomposition and trigonometry in tension force analysis, participants clarify the roles of sine and cosine in relation to angles in right triangles. Sine is associated with the vertical component, while cosine corresponds to the horizontal component, based on trigonometric principles. The importance of understanding vector decomposition is emphasized, particularly in analyzing forces. Participants suggest drawing a labeled right triangle to visualize the tension force and its components. Overall, the conversation focuses on applying trigonometric functions to resolve forces in physics problems.
Scorry
This is a solved problem. It is attached. Why is sin theta horizontal, and cosine theta vertical?
All relevant equations are given.
The solution is given.
You'll have to be more specific.
The short answer is: Because trigonometry says so.
Its been a while since I have seen trig. Can you explain how I should look at it? It says theta is relative to the vetical.
Are you familiar with SOH CAH TOA?
Can you draw a labelled right angled triangle with FT as the hypotenuse?
Yes remember those 3 trig functions. I can draw a right triangle with the hypotenuse labeled Tension force. Where are you going with this?
I'm trying to ascertain what exactly you are having trouble with. Do you understand vector decomposition? Do you understand why you need to do it in this case? Can you use trig to find lengths of a right triangle sides?
'draw a labelled right angled triangle' = include all information you have. Orientation relative to x & y axis, theta, Label the other sides descriptively ie FT,X FT, Y. Using SOH CAH TOA, what are the lengths of the opposite and adjacent sides?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
