What is the relationship between tension force and SHM?
The relationship between tension force and simple harmonic motion (SHM) is rooted in Hooke's law, which states that the restoring force of a spring is proportional to the displacement from its equilibrium position. When a mass attached to a spring is displaced, the spring exerts a tension force in the opposite direction to restore it to equilibrium. This continuous application of force leads to oscillation, resulting in SHM, characterized by periodic motion. The discussion emphasizes that the spring's behavior is consistent and predictable, adhering to the principles of ideal springs. Understanding this relationship is crucial for grasping the fundamentals of SHM.
Peter G.
Hi,
I am learning about SHM and in order to explain why the acceleration is proportional to the displacement but in opposite directions the book used as an example a particle with mass m, attached to a spring.
He defines the displacement to the right as being positive and to the left as being negative.
When the particle is displaced to the right, x, the extension, will be positive. The tension in the spring is towards the left. But why? Is it a characteristic of the spring to always have its force trying to restore the spring to its equilibrium position?
Thanks,
Peter G.
Absolutely. Ideal springs obey Hooke's law.
And whenever the restoring force is proportional to the displacement from equilibrium, the resulting motion will be simple harmonic motion.
Yes. This is how Hooke's law is typically expressed F=-kx
Where x is the displacement from the equilibrium position and k is the spring constant. There are a number of different and non-intuitive ways to come to this conclusion (you will cover springs in differential equations and a course on thermal/statistical physics), but the physically intuitive understanding is that a spring will apply a force to a mass at any point other than it's equilibrium position. If it is moved away from that position, the spring then applies a force to move it in, and, in an undamped case, will continue applying force until the mass is past the equilibrium position in the opposite direction, to which the spring will then a apply a force in reverse. This leads to oscillation, and will be infinitely periodic in the undamped and frictionless case.
Ok, thanks guys!
