Tension in a String: Is T1 > T2?
  • Thread starter Thread starter physics kiddy
    String Tension
The discussion revolves around understanding the relationship between tensions T1 and T2 in a pulley system with two masses, 2m and m. It is clarified that if the pulley is massless and frictionless, the tensions on both sides of the pulley will be equal, meaning T1 equals T2. However, if the pulley has mass, the tensions can differ, and the moment of inertia must be considered. The confusion arises from the assumption about which tension corresponds to which mass, but ultimately, the consensus is that T1 and T2 are equal when the system is balanced. The key takeaway is that in a massless and frictionless scenario, T1 does not exceed T2.
physics kiddy
I have attached a pic with my question. I want to know if T1>T2 or not.
As much as I know, Tension in a string = Earth's Gravitational force. But this question is quite confusing.
T=2m1m2g
(m1+m2)
t2 would be greater if the mass in t2 is greater than the mass in t1
Is the pulley massless and frictionless? That's the key.
Careful! That's not true. In general you'll have to solve for the tension in the string by applying Newton's 2nd law.
T1 has a mass greater than T2.
I don't know what you mean. T1 and T2 are tensions. Regardless of the size of the mass on the ends of the string segment, the tension on both sides of a massless and frictionless pulley will be the same.
Since the mass on each side of the pulley is the same (2m on each side, added up), it turns out that in this particular case the tension T1 = T2 = 2mg. (The masses don't accelerate.)
Agree completely with DocAl and will add that the tension in a string is the same everywher... all the way along it.
There is no resultant force on this system so it is either at rest or moving with constant velocity (speed) in one direction or the other.
The only string with a different tension is between the 2 masses m and m ...the tension in here will be mg
The tensions T1 and T2 will be 2mg
I personally think that T2 was meant for the second string connecting the masses on the right side of the pulley. Because usually the pulley doesn't have mass (for beginner class) and the tension is uniform in one continuous string (and this is assumed rather than stated). So... I worked out the problem w these assumptions below. Check it out. So the solution looks like T1>T2.
Only if the string is also of negligible mass :biggrin:
And if the pulley has some mass, you can find its moment of inertia and apply the equations of torque:
T_1 R - T_2 R = I\alpha = \frac{Ia}{R}
Here I is moment of inertia of pulley and R is its radius ...
And if pulley has no mass, I=0 ...
I apologize for confusing you all. I am sorry. I have cleared my doubts with the question. The question was that there's a pulley and two masses 2m and m are tied to the opposite ends of the pulley as shown in the figure. The tension between 2m and pulley is T1 and between m and pulley is T2. Is the tension T1>T2?
The pulley and string are assumed to be massless and frictionless.
Are you sure that T2 refers to the tension between m and the pulley and not between m and m?
(Is this your diagram, or the one given with the problem?)
Yes, I am sure.
physics kiddy said:
Yes, I am sure.
In that case, your question has already been answered.
I can't figure out where the answer is. Please explain it once again. Thanks
See post #6.
