Is there a mistake in this tensor multiplication problem?
DuckAmuck
Show that
epsilon_{ijkl} ( M^{ij} N^{kl} + N^{ij} M^{kl}) = 0
epsilon is the 4D anti-symmetric Levi-Cevita tensor. M and N are also anti-symmetric tensors.
ep_{ijkl} M^{ij} N^{kl} + ep_{ijkl}N^{ij} M^{kl}
The second term can be rewritten with indices swapped
ep_{klij} N^{kl}M^{ij}
Shuffle indices around in epsilon
ep{klij} = ep{ijkl}
Therefore the expression becomes
2ep_{ijkl}M^{ij}N^{kl}
Not zero.
What is wrong here?
I tried, but got the same result as you did. Are you sure its not supposed to be
##\epsilon_{ijkl} ( M^{ij} N^{kl} - N^{ij} M^{kl}) = 0##?
What I did was to write everything out, using all even permutations of 1,2,3,4:
{1,2,3,4}, {1,3,4,2}, {1,4,2,3}, {2,1,4,3}, {2,3,1,4}, {2,4,3,1}, {3,1,2,4}, {3,2,4,1}, {3,4,1,2}, {4,1,3,2}, {4,2,1,3}, {4,3,2,1}
and all odd ones:
{1,2,4,3}, {1,3,2,4}, {1,4,3,2}, {2,1,3,4}, {3,2,1,4}, {4,2,3,1}, {2,3,4,1}, {2,4,1,3}, {3,1,4,2}, {3,4,2,1}, {4,1,2,3}, {4,3,1,2}
and the fact that ##M## and ##N## are anti-symmetrical, i.e. ##M^{12}= - M^{21}## etc.
ok i think i have solid reasoning here:
Suppose ##C^{ij} = M^{ij} + N^{ij}##
From symmetry and antisymmetry we have:
##\epsilon_{ijkl} C^{ij}C^{kl} = 0##
Also if you foil the CC product in terms of M and N you get ##C^{ij}C^{kl} = M^{ij}M^{kl} + N^{ij}N^{kl} + M^{ij}N^{kl} + N^{ij}M^{kl}##
The MM and NN terms are zero for the same reason the CC product is when multiplied by epsilon.
So this demands that
##\epsilon_{ijkl} (M^{ij}N^{kl} + N^{ij}M^{kl}) = 0##
Can someone please verify?
No, the statement as it stands seems false to me. It is not generally the case thar ##\epsilon_{ijkl} C^{ij} C^{kl} = 0##.
Likes malawi_glenn
You’re right. I am just trying to figure out *how* this could be zero at this point, as in what conditions. Otherwise I’m stumped.
You should have been given all the conditions already, that M and N are antisymmetric rank-2 tensors.
There is always the possibility that whoever gave you this problem, is wrong / made a typo. I have been tearing my hair off several times doing excersices in general relativity books... to find out there was some typo in the problem as written.
Here is my "expanded" calculation that I did btw:
The underlined terms I will collect at the end.
## \underline{M^{12}N^{34}} + M^{13}N^{42} + M^{14}N^{23} + \underline{M^{21}N^{43}} + M^{23}N^{14} + M^{24}N^{31} + M^{31}N^{24} + M^{32}N^{41} + M^{34}N^{12} + M^{41}N^{32} + M^{42}N^{13} + M^{43}N^{21} ##
##- ( \underline{M^{12}N^{43}} + M^{13}N^{24} + M^{14}N^{32} + \underline{M^{21}N^{34}} + M^{32}N^{14} + M^{42}N^{31} + M^{23}N^{41} + M^{24}N^{13} + M^{31}N^{42} + M^{34}N^{21} + M^{41}N^{23} + M^{43}N^{12} )##
##+ N^{12}M^{34} + N^{13}M^{42} + N^{14}M^{23} + N^{21}M^{43} + N^{23}M^{14} + N^{24}M^{31} + N^{31}M^{24} + N^{32}M^{41} + \underline{N^{34}M^{12}} + N^{41}M^{32} + N^{42}M^{13} + \underline{N^{43}M^{21}} ##
##- ( N^{12}M^{43} + N^{13}M^{24} + N^{14}M^{32} + N^{21}M^{34} + N^{32}M^{14} + N^{42}M^{31} + N^{23}M^{41} + N^{24}M^{13} + N^{31}M^{42} + \underline{N^{34}M^{21}} + N^{41}M^{23} + \underline{N^{43}M^{12}} \: ) ##
The stuff I underlined:
## M^{12}N^{34} + M^{21}N^{43} - M^{12}N^{43} - M^{21}N^{34} + N^{34}M^{12} +N^{43}M^{21} -N^{34}M^{21} - N^{43}M^{12} ##
(##M^{21}= - M^{12}## and ##N^{43}= - N^{34}##)
##M^{12}N^{34} + (-1)^2 M^{12}N^{34} - (-1)M^{12}N^{34} - (-1)M^{12}N^{34} + N^{34}M^{12} +(-1)^2N^{34}M^{12} - (-1)N^{34}M^{12} - (-1)N^{34}M^{12} = 8M^{12}N^{34} ##
Well that was fun.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
