Understanding Well-Defined Tensor on Manifold: Basic Concepts
binbagsss
I'm trying to understand what exactly it means by some tensor field to be 'well-defined' on a manifold. I'm looking at some informal definition of a manifold taken to be composed of open sets ##U_{i}##, and each patch has different coordinates.
The text I'm looking at then talks about how in order for a tensor field to be defined globally there are certain transition laws that must be obeyed in intersecting regions of ##U_{i}##
From this, my interpretation of well-defined is that you have in variance in certain patches, and so because each patch has its own coordinates, you have in variance in any coordinates. So, a tensor means you have invariance with respect to a change in coordinate system?Are these thoughts correct?
Is this literal agreement? I.e- the value of a scalar? the components of a matrix (representing a tensor as a matrix)?
Thanks in advance.
To say that something is "well defined" typically means that whatever you have previously said about it is sufficient to actually define it. So you may need to tell us that we what said previously.
I will make a guess based on what you said. I would define a vector field on a smooth manifold ##M## as a function that associates a tangent vector at p with each ##p\in M##. It sounds like their version of this is a function that associates an n-tuple of real numbers with each pair ##(p,x)## such that ##x:U\to\mathbb R^n## is a coordinate system such that ##p\in U\subseteq M##. This type of function indirectly defines a tensor, if and only if for all ##p\in M## and all coordinate systems ##x:U\to\mathbb R^n## and ##y:V\to\mathbb R^n## such that ##p\in U\cap V##, the relationship between the n-tuple associated with ##(p,x)## and the n-tuple associated with ##(p,y)## is given by the tensor transformation law.
Neither coordinates nor the definition of a manifold using an atlas of charts is relevant here. If all you want to do is define what it means for a tensor to be well-defined on a manifold, all you need to consider is the manifold as a point-set; the tensor just has to be defined at every point in the point-set. (Of course, if the tensor has rank>0, then you need enough of the manifold structure to be able to define a tangent space.)
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
