Tensors of Relativity: Inner vs Outer Indices
  • Thread starter Thread starter praharmitra
    Relativity Tensors
praharmitra
I am a bit confused with tensors here.
now i know that \Lambda, the transformation matrix has a different meaning when I write
\Lambda^\mu\ _{\nu} and when I write \Lambda_{\nu}\ ^\mu
One is the mu-nu th element of \Lambda and the other is the mu-nu th element of \Lambda^{-1}.
Is it the same for tensors. I mean is F^\mu\ _{\nu} different from F_{\nu}\ ^\mu ?
If there is a difference of writing inner and outer indices what is it?
From what I've seen, inner and outer indexes is only a convention used to distinguish the two cases, and there are at least two other conventions:
For example, in:
http://www.teorfys.uu.se/people/minahan/Courses/SR/tensors.pdf
both the rotation and the inverse rotation are written lower index out (but primes are used to distinguish if forward or inverse rotation is implied).
An alternate convention appears to be to just use a different symbol for the forward and inverse transformations. In:
http://qmplus.qmul.ac.uk/pluginfile.php/301050/mod_resource/content/2/EMT7new.pdf
That author uses
<br /> {\Lambda^\mu}_\nu<br />
and:
<br /> {(\Lambda^{-1})^\alpha}_\beta<br />
... everything I know about tensors is self taught, so I'm no authority, but I'm pretty sure that I've seen all three variations of index conventions used in various papers I've attempted to read.
I understand its just a notation. I guess its you did not understand my question. I am asking whether the same applies for tensors. Remember, \Lambda is NOT a tensor. It is only the transformation matrix.
However for tensors, like the electromagnetic field tensor T, does the outer and inner indices have any meaning?
I would give those tensors the following meaning:
<br /> \begin{align*}<br /> F^{\mu\nu} &amp;= \partial^{\mu} A^{\nu} - \partial^{\nu} A^{\mu} \\<br /> F_{\mu\nu} &amp;= \partial_{\mu} A_{\nu} - \partial_{\nu} A_{\mu} \\<br /> {F^{\mu}}_{\nu} &amp;= \partial^{\mu} A_{\nu} - \partial_{\nu} A^{\mu} \\<br /> {F_{\mu}}^{\nu} &amp;= \partial_{\mu} A^{\nu} - \partial^{\nu} A_{\mu}<br /> \end{align}<br />
But I don't have any texts that cover maxwell's equations in tensor form to confirm. The statement above is from personal notes where I was "translating" between the bivector and tensor forms of maxwell's equations:
http://sites.google.com/site/peeterjoot/geometric-algebra/maxwell_to_tensor.pdf
No guarantee of correctness, so you will have to use your own judgement to verify if this seems right.
1. \Lambda IS a tensor, as well as defining the LT.
2. Raising and lowereing indices are performed by the metric tensor g_{\mu\nu},
and gives different components. It does not always produce an inverse.
This just happens to happen for \Lambda.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
