Term used in magnetism for grade 9
  • Thread starter Thread starter songoku
    Magnetism Term
The path along which a free north pole end of a magnet would point is referred to as a magnetic field line. When a magnet is free to rotate, it aligns itself to minimize potential energy in the local magnetic field, resulting in a net torque of zero. In the context of Earth's magnetic field, the term "meridian" is used to describe the abstract line connecting the Earth's north and south poles, where all points on a given meridian share the same longitude. This concept helps clarify the alignment behavior of magnets in relation to Earth's magnetic field.
songoku
What is the name given to the path along which a free north pole end of a magnet would point?
Name of a "path"? The name is magnetic field line? north pole?
What do you mean by "a free north pole end of a magnet"? The north pole of a magnet that's free to rotate in any direction?
If that is the case, then I'm not aware of any specific name for this "path". The magnet will tend to align itself so as to minimize the potential energy in the local magnetic field (so that the net torque acting on the magnet is zero).
Likes songoku
Not sure. I got this question from 9 grader and the girl showed me the photo of the question. The full wording is exactly as I wrote.
I have tried googling but to no avail
I think the exercise wants to name the path that the magnet will align itself in the presence of the magnetic field of the earth. It is called Meridian, the abstract line that connect the north pole to the south pole of the Earth and all the points of a given meridian have the same longitude.
Likes songoku
Thanks for your help gneill and delta
Hello, I’m currently writing a series of essays on Pangaea, continental drift, and Earth’s geological cycles. While working on my research, I’ve come across some inconsistencies in the existing theories — for example, why the main pressure seems to have been concentrated in the northern polar regions. So I’m curious: is there any data or evidence suggesting that an external cosmic body (an asteroid, comet, or another massive object) could have influenced Earth’s geology in the distant...
On August 10, 2025, there was a massive landslide on the eastern side of Tracy Arm fjord. Although some sources mention 1000 ft tsunami, that height represents the run-up on the sides of the fjord. Technically it was a seiche. Early View of Tracy Arm Landslide Features Tsunami-causing slide was largest in decade, earthquake center finds https://www.gi.alaska.edu/news/tsunami-causing-slide-was-largest-decade-earthquake-center-finds...
