- 37,009
- 16,011
The question referred to here explicitly stated that it was attached.A.T. said:If attached to each other, a negative compressive force gives the tension in the attachment.
Originally Posted by Studiot
Well first point is that both D'Alembert's and Newton's methods will lead to an invalid conclusion if inappropriately applied.
This triviality is quite a backpedaling compared to "D'Alembert's method will definitely get you the wrong answer". How is that problem relevant to this thread, which about comparing the two approaches?
It surely is never negative.
A negative numerical result for a contact force which is defined as compressive is perfectly valid, if interpreted correctly. It means that the bodies will separate if not attached to each other, so the initial situation stated in the question will change. If attached to each other, a negative compressive force gives the tension in the attachment.
Studiot said:[..] both D'Alembert's and Newton's methods will lead to an invalid conclusion if inappropriately applied.
The question was specifically constructed (not by me) to demonstrate the particular point that it is posible to step outside the obvious assumptions and thereby obtain the 'wrong' answer.
[..] The relevant equation, by either method, is
[tex]R = 4.93 - \frac{{\sqrt 3 }}{4}{\omega ^2}[/tex]
I make the ω at which R becomes zero the 3.374 I posted.
Various values for R, including negative ones were offered, but none if I recall correctly equal to zero.
Whirling beyond this speed simply causes enough tension in the string to lift the mass of the cone.
Of course R remains zero or is non existant. It surely is never negative.
Misapplication of methods will give the wrong answer for any problem. Unless you make two errors that cancel each other.Studiot said:I am trying to show Harrylin that it is possible to find problems where misapplication of either method will lead to the wrong answer,
You are talking about a tetherball physics problem. That is not the correct setup for this problem.Ken G said:It appears from your diagram that the mass is suspended from a string, and lies against the cone. If so, there are three real forces on the mass-- the tension from the string (which points along the string), gravity (which is downward), and the normal force from the cone (which is perpendicular to the cone surface).
Studiot said:A (point) mass m is attached to a smooth cone of 60 angle.
None of that was specified in the problem. This is Physics Forum, not Psychics Forum. You cannot post an inconsistent or incomplete problem and then claim failure of some analysis technique by the resulting "mistakes". The question itself was bad.Studiot said:The mass is not attached to the cone by adhesive which would be needed to obtain a negative reaction force.
It is attached by the string which would be unecessary if adhesive were to be used.
Studiot said:[Dynamics 4.2]
I would very much like to see the previous page with the problem description. I suspect it is much more complete than your rendition.Studiot said:At last someone with some good manners and an open mind.
Please.Studiot said:At last someone with some good manners and an open mind.
Studiot said:Apologies, the string is 2m long and the mass is 2kg.
That's my point, it is a tetherball problem only if the angular velocity is above the limit discussed earlier, and it appears to be in this case (though the constraints have emerged somewhat fitfully). That is inconsistent with the description that the cone is providing the angular velocity. So that's the claim I'm making-- the problem is internally inconsistent.D H said:You are talking about a tetherball physics problem. That is not the correct setup for this problem.
The cone would be a meaningless complication were this the correct setup; you might as well just have a vertical pole.
you'll note that the critical angular velocity where the normal force goes to zero doesn't even depend on the mass of the object.
Which part of that did you not understand?Studiot said:pardon?
Even so, the simple analysis yields a normal force of zero, or negative, in the inappropriate situations. That's something the user should notice if they are serious about what they are doing. In other words, it doesn't require some deep appreciation for the mysteries of inertia, it just requires that someone has a clue, an interest in actually mastering their own craft rather than just faking their way through. The lesson is true, we all must constantly ask ourselves "does this make sense" at every stage of a calculation-- but that goes almost without saying for anyone who has done calculations and wants them to mean something.D H said:Who is at fault? Well, you are, or whoever accredited this model for use in this new simulation. That freebie model should never have been used as-is.
Although, if the ball is attached to the cone, as was stated, then a negative force is appropriate and makes sense.Ken G said:Even so, the simple analysis yields a normal force of zero, or negative, in the inappropriate situations. That's something the user should notice if they are serious about what they are doing. In other words, it doesn't require some deep appreciation for the mysteries of inertia, it just requires that someone has a clue, an interest in actually mastering their own craft rather than just faking their way through. The lesson is true, we all must constantly ask ourselves "does this make sense" at every stage of a calculation-- but that goes almost without saying for anyone who has done calculations and wants them to mean something.
Exactly. So one must always know what one is doing, but the forces come out what they would need to. It's much like with computer programming-- don't blame the computer when it does what it is asked to do, the user has to make sure they are posing the problem they think they are posing, so the "does this make sense" test must be applied often. (By the way, the problem is more interesting if the mass is hung from a string. It's hard to tell, the language used is very vague, but it looks like there is supposed to be a string, despite the use of the term "attached"-- it is attached by a string? If it hangs from a string, but comes to equilibrium against the surface of the cone via friction and the rate of the cone's rotation, then it is only "attached" to the side of the cone for the slower rotation-- for rotation past the critical limit, the mass will begin a very chaotic stick-slip kind of motion that would be very difficult to analyze.) Anyway, the problem was supposed to show us how to separate "real" forces from "inertial" ones, and that I would say is a complete red herring here, because no one needs to invoke inertial forces at all, though they may certainly choose to use that language for the ma term if they are clear about it. All the same, massless objects never have inertial forces, so the whole idea that there would be inertial forces on the massless string (which is where this all started) is clearly wrong.DaleSpam said:Although, if the ball is attached to the cone, as was stated, then a negative force is appropriate and makes sense.
While it might be simple to see the problem in this simple case, seeing the problem in a complex system is, well, complex. Seeing the problem that will lead to loss of life, mission failure, or some other catastrophe ahead of time is getting harder and harder ss systems become ever more complex. Failing to see the problem led to the crash of the initial flight of the Ariane 5, the loss of the Mars Climate Orbiter, the crash of the Mars Polar Lander, the failure of the DART (Demonstration of Autonomous Rendezvous Technology) mission, the loss of Milstar-2 F1, two Shuttle flights, and others, and that is just in the aerospace field.Ken G said:Even so, the simple analysis yields a normal force of zero, or negative, in the inappropriate situations. That's something the user should notice if they are serious about what they are doing. In other words, it doesn't require some deep appreciation for the mysteries of inertia, it just requires that someone has a clue, an interest in actually mastering their own craft rather than just faking their way through. The lesson is true, we all must constantly ask ourselves "does this make sense" at every stage of a calculation-- but that goes almost without saying for anyone who has done calculations and wants them to mean something.
