Understanding the Tetrad Formalism in General Relativity
  • Context: Graduate
  • Thread starter Thread starter Higgsono
    tetrad
The discussion revolves around the tetrad formalism in general relativity, specifically addressing the necessity and implications of introducing tetrads as orthonormal bases of smooth vector fields on manifolds. Participants explore the differences between tetrads and coordinate bases, particularly in the context of curvature and the challenges of maintaining orthonormality across different regions of a manifold.
  • Some participants assert that introducing a tetrad involves defining an orthonormal basis of vector fields that satisfy specific conditions at each point on the manifold.
  • Others question why a coordinate system cannot be chosen to make the coordinate basis orthonormal at every point, suggesting that this might relate to the number of charts needed to cover the manifold.
  • It is noted that while a coordinate basis can be orthonormal at a single point, it may not remain so in regions of non-zero curvature.
  • Examples are provided, such as the Earth's surface, where coordinate systems become distorted near the poles, complicating the establishment of orthonormal bases.
  • Some participants argue that a global orthonormal basis cannot be constructed on certain manifolds, such as the sphere, due to singularities at specific points.
  • There is a discussion about the possibility of constructing local tetrads versus global tetrads, with some asserting that local tetrads are sufficient for most applications.
  • Confusion arises regarding the relationship between tetrads and coordinate systems, with participants attempting to clarify the distinctions in terms of tangent vectors defined on the manifold versus those from R^n.
Participants express differing views on the feasibility of using coordinate systems to achieve orthonormal bases across a manifold. There is no consensus on whether a global tetrad can be constructed, with some asserting it is impossible while others suggest local tetrads may suffice.
The discussion highlights limitations related to the curvature of manifolds, the nature of coordinate systems, and the challenges of maintaining orthonormality across different regions. The implications of the Hairy Ball theorem are also referenced in relation to the impossibility of finding global non-singular vector fields on certain surfaces.
This discussion may be of interest to students and professionals in physics and mathematics, particularly those focusing on general relativity, differential geometry, and the mathematical foundations of curved spaces.
Higgsono
Correct me if I'm wrong. But my understanding is the following.
Introducing a tetrad, means introducing an orthonormal basis of smooth vector fields, satisfying
##(e_{\mu})^{a}(e_{\nu})_{a} = \eta_{\mu\nu}## at each point. That is, we define a set of 4 vector fields such that they are orthogonal at each point on the manifold.
But then my question is. Why can't we just choose a coordinate system such that our coordinate basis ##\Big\{\frac{\partial}{\partial x^{\mu}}\Big\}## is orthonormal at each point? Why do we need to introduce a vector field on top of our coordinate system to have a basis that is orthonormal at each point?
I suspect that it has to do with the number of charts we want to cover the manifold with. But I'm not sure. For instance on a sphere we can use the coordinate basis because it is everywhere orthonormal, and so we do not need to introduce a tetrad by adding additional vector fields.
You can choose a coordinate system so that at a single point, the coordinate basis is orthonormal. But if the curvature is nonzero, then away from that point, it will no longer be orthornormal. ("Orthonormal" isn't really the right word, since that implies that each vector has norm +1. You mean that the base vectors have norm ##\pm 1##)
What I think may be the simplest example showing that it is impossible to do what you want, consider the surface of the Earth. The usual coordinate system is ##\theta, \phi## where ##\phi## is longitude and ##\theta## is latitude. At the equator, the basis vectors for those coordinates are orthonormal (or can be made orthonormal by scaling appropriately). But near the North and South poles, the coordinate system is greatly distorted from being Cartesian, so they don't have orthonormal basis vectors.
But how do you choose a vector field so that they remain orthonormal everywhere on the sphere? Do we not have the same problem here? And we can always cover the surface on a sphere with 2 coordinate systems.
The easiest way to see that such a coordinate system can only exist if the manifold is flat is that the metric components would all be constant. This would mean that all Christoffel symbols (of the Levi-Civita connection) would be zero, since they can be expressed in terms of the inverse metric and the partial derivatives of the metric components - if the metric components are constant these derivatives would all be zero. Since the components of the Riemann curvature tensor are expressed in terms of the connection coefficients, they would all be zero - implying that the manifold (with the Levi-Civita connection) is flat if such coordinates exist.
Not sure that this is a good example, it is just an example of a coordinate system where this does not happen - not a proof that no such system can exist.
You cannot find a global orthonormal basis on the sphere.
Edit: See https://en.wikipedia.org/wiki/Hairy_ball_theorem
Latitude and longitude are perpendicular, so all you have to do in this case is to divide the coordinate basis vectors by their norm. Not all coordinate systems are orthogonal, so that cannot always be done.
You still miss the poles of course
This does not provide you with a global orthonormal basis. Those fields would be singular at the poles.
Ok, so how do I construct a tetrad on the 2-sphere then?
There is no global tetrad. You can only construct local tetrads. For most purposes, this is enough.
But if we consider only the upper half of the 2 sphere, then we can choose a coordinate system, for instance spherical coordinates, so that the metric components are constant everywhere. Now I have constructed a tetrad, but this is no different then just choosing a suitable coordinate system. I don't understand, what am I missing?
No you cannot. Spherical coordinates do not give you constant metric components.
Orodruin said:
No you cannot. Spherical coordinates do not give you constant metriccomponents.
ok, so the difference between using a tetrad or coordinate basis is that a coordinate basis uses the tangent vetors (partial derivatives) from R^n, while a tetrad uses tangent vectors (partial derivatives) defined on the manifold?
No. Both the tetrad and the holonomic basis are tangent vector fields on the manifold. Each can be expressed in terms of the other. The difference is that one is orthonormal and the other holonomic.
ok, so basically I don't understand the concept of tetrad at all. Don't we need to specify coordinates in order to define a tetrad on the manifold? edit: or maybe I understand it better now. I guess I was confused with the difference between coordinate system and vector field.
So my understanding is this. Introducing a tetrad on M is basically the same as introducing a coordinate system on M such that the tangent vectors to the coordinate curves are orthogonal.
No. Again, this is not correct. Your tetrad does not need to be based on any coordinate system whatsoever. It is just a complete set of vector fields that are orthonormal.
eeh ok, but how do I define a vector field without coordinates? If the metric should be Minskowski, does that not imply that they are defined using coordinates. How could you otherwise take their inner product?
No. Sometimes you can make a very meaningful tetrad in situations where a coordinate system is problematic. For example it is easy to construct a tetrad for a family of observers on a rotating disk, but because of simultaneity constructing a coordinate system is problematic.
The way I think of it is that the tetrad represents the physics. The coordinates are just labels.
A vector field is independent of any coordinates you define. It will be the same vector field regardless of what coordinates you have introduced.
The metric is just a (0,2) tensor field, it is a (0,2) tensor at each point. The requirement on the tetrad is that letting the metric take two different tetrad vectors should always give you zero and if you let it take the same it should give you +(-)1.
You do not need coordinates to talk about components of a tensor. What you need is a basis for the tangent space. You can get such a basis from a coordinate system by considering the corresponding holonomic basis and the corresponding components are what is referred to as the components in those coordinates. But the basis you choose need not be holonomic.
Yes, we have the same problem. That was my point: You can't come up with a coordinate system on the sphere where the coordinate basis is always orthonormal.
Not an orthonormal one.
Well, it wasn't offered as a proof, it was offered as an example.
Well, are tetrads supposed to be only used within a simply connected region? If so, Dale's construction works fine in a small region of the Earth.
As for globally, doesn't the theorem that you can't comb a sphere imply that there is no way to do it?
[edit] I see that @Orodruin already made this point.
Are tetrads required to be smoothly varying from point to point? If not then you can certainly have a tetrad covering the sphere. Just form the usual latitude and longitude tetrad and then choose an arbitrary set of vectors at the poles.
Typically, yes.
Orodruin said:
Typically, yes.
I couldn’t find an online reference that specified that as a requirement.
Well, I guess as anything concerning differentiable manifolds you can define smooth tetrad fields within a single map, but an atlas usually will necessarily consist of more than one map to cover the entire manifold. E.g. for the sphere in 3D Euclidean space any atlas contains at least two maps.
For coordinate maps yes, you are absolutely right. But there is no need for a tetrad to be tied to a coordinate chart at all, so the coverage limitations on charts may not apply to tetrads.
For example, on the sphere you can form the usual latitude and longitude based tetrads everywhere except the poles, and on the poles you can simply pick an arbitrary direction as your ##x_1## direction and then the ##x_2## vector is determined. Then you have a tetrad field which covers the entire sphere whose only problem is smoothness at the poles. I just have not found an authoritative source which stipulates smoothness as a requirement for a tetrad, although it is the usual case.
I don't see how a non-smooth tetrad would be of practical use. To me, a very important property is to write smooth vector fields as linear combinations ##Y = Y^a e_a##, where the ##e_a## are the tetrad fields and the ##Y^a## are smooth functions (components in terms of the tetrad). The nice properties of writing a field like that are quite diminished if ##e_a## are no longer smooth themselves.
My point was exactly this. The topology of the manifold is locally defined to be that of ##\mathbb{R}^d##, and it's the maps which defines this local topology and thus what continuous means for functions on the manifold. A differential manifold as a whole is defined by atlasses consisting of compatible maps, and the compatibility between laps on overlap regions makes the manifold a whole. Thus you also need to define tetrade fields piecewise on maps with some consistency condition in the overlap regions. I guess at each point in the overlap region the tetrad field defined on one piece must be given by a ##\mathrm{SO}(m,n)## (for relativity it's of course ##(m,n)=(1,3)## or ##(m,n)=(3,1)## depending on your preferred east- or west-coast convention for the fundamental form). However, I'm not aware of any textbook which defines tetrades (or more generally ##(m+n)##-beins) globally.
An example: page 49 of "General Relavity" by Wald, "noncoordinate, orthonormal basis of smooth vector fields ##\left( e_\mu \right)^a## ... ##\left\{\left( e_\mu \right)^a \right\}## is called a tetrad."
  • · Replies 28 ·
  • · Replies 27 ·
  • · Replies 47 ·
