The best way to liquefy Ammonia
  • Thread starter Thread starter pranj5
    Ammonia
The most economical method to liquefy ammonia (NH3) vapor at -33°C involves pressurization and cooling techniques. Increasing the gas pressure raises the temperature, keeping NH3 in a gaseous state, while allowing it to cool under the right pressure/temperature ratio facilitates liquefaction. Utilizing a well-made vacuum flask for insulation and circulating liquefied gas at -33°C is effective. Additionally, industrial refrigeration units are recommended for practical implementation, with Linde's Process and Claude's Process being notable methods for ammonia liquefaction.
  • Understanding of ammonia's phase change properties
  • Knowledge of pressurization and cooling techniques
  • Familiarity with refrigeration cycles and systems
  • Basic principles of thermodynamics related to gas expansion
  • Research Linde's Process and Claude's Process for ammonia liquefaction
  • Explore industrial refrigeration units and their specifications
  • Investigate the use of expansion in gas cooling systems
  • Examine the efficiency of Peltier modules for low-temperature applications
Chemical engineers, refrigeration technicians, and professionals involved in industrial ammonia handling and liquefaction processes.
pranj5
Suppose, there is an amount of Ammonia vapour at atmospheric pressure and very very close to the boiling point say at -33°C. I want to know what's the best way to liquefy the Ammonia in terms of economy and energy. I know that it can be liquefied with cold fluids like liquid Nitrogen etc., but what's the most economic way?
Pressurization.
You increase the gass pressure, at which point gas temperature also rizes - and hence keeps NH3 in gaseous state.
You let the gass cool down and when the pressure/temperature ratio falls to the right ratio the NH3 liquefies.
I can understand, but how to maintain the temperature at such low level.
You said you already have NH3 at -33°C, i presumed you meant at some high altitude (or polar region) which means you just need to keep the gass there.
If you are in STP conditions, you would need a well made vacuum flask for insulation, and you can keep it cool by circulating liquefied gas at -33°C inside it. To cool that cooling gass/liquid you use expansion.
An alternative would be to use a peltier module but i think efficiency would be lower (i'm not sure though) than with the above method.
The Ammonia is at -33°C doesn't mean that the surrounding temperature is like this. This simply means that the Ammonia to be liquefied is at -33°C i.e. very close to its boiling point at atmospheric pressure. Question is what's the best and energy efficient way to liquefy the Ammonia. Kindly clarify what do you mean by using expansion. Can you suggest some kind of machinery that can do the job?
Check Linde's Process and Claude's Process. You will find patents and blueprints/schematics for both on google.
Expansion - when you increase the volume of a gas while keeping its mass the same its temperature decreases. Return the process for increassing the temperature.
Most modern refridgeration and air conditioning systems work in this manner.
Thanks! But I need machinery and information about what kind of manufacturers can make such machinery.
Ammonia is used as the refrigerant in low temperature chillers. Just google for that.
  • · Replies 21 ·
  • · Replies 28 ·
