The Curious Case of Pascal Barrels
  • Context: Undergrad
  • Thread starter Thread starter Usamah Jundi
    Curious Pascal
The discussion revolves around fluid statics, specifically the hydrostatic pressure in a cylindrical barrel filled with water. Participants explore the calculation of forces acting on the barrel, the pressure distribution, and the implications of Pascal's experiment regarding bursting barrels.
  • Usamah questions whether to calculate the total force inside the barrel by summing the forces on the lid, sides, and bottom, and how to approach pressure calculations.
  • Some participants suggest that the force inside the barrel should consider the absolute force difference between the inside and outside, integrating pressure over the barrel's area.
  • There is a discussion about the contribution of atmospheric pressure and how it cancels out in certain calculations, particularly in relation to Pascal's experiment.
  • Participants mention that the pressure at the fluid level in the barrel is influenced by both the height of the liquid in the barrel and the height of the liquid in the tube.
  • Usamah expresses confusion about whether the water inside the barrel contributes to the force exerted on the sides, which is confirmed by other participants.
  • A later reply clarifies that the average pressure can be calculated using the midpoint of the barrel's height, as the pressure varies linearly with height.
  • Usamah concludes with a formula for total force after integration, indicating a developing understanding of the concepts discussed.
Participants generally agree on the need for a complete problem description and the approach to calculating forces and pressures. However, there are nuances in how to interpret the contributions of atmospheric pressure and the integration process, indicating some unresolved aspects of the discussion.
Some assumptions about the conditions of the barrel (e.g., being closed, filled with water, and positioned vertically) are necessary for the calculations discussed. The discussion also highlights the importance of specifying the context to avoid confusion.
This discussion may be useful for students or enthusiasts of fluid mechanics, particularly those interested in hydrostatic pressure and its applications in real-world scenarios like Pascal's experiments.
Usamah Jundi
Hello! I've been confused about fluid statics, to be more specific, about the hydrostatic pressure. supposedly i have a cylindrical barrel of height h and radius of r:
(a). if i were to calculate the total Force inside the barrel, do i use the (Force on the lid + Force on the Sides + Force on the bottom) while the pressure on the sides is defined as an integration of the dF = P * dA ?
(b).how about the pressure?
and
(c) i suppose you guys have seen the Pascal's Experiment on Bursting the barrel with a long tube on top of the barrel filled with water. is the pressure inside the barrel only the hydrostatic pressure of the water inside the tube plus the average pressure inside the barrel ( i suppose the atmospheric pressure cancels out because it's applied to the tube and the barrel) , or i can just calculate the force by using the hydrostatic pressure of the water + the integration of the dF on the sides of the barrel, and the Force on the lid and bottom?
if i have to use the average pressure, why?thanks!
forever in curiousity,
Usamah Jundi Abdillah.
Hello Usamah, :welcome:
Is not enough to completely describe the situation. For completeness, consider adding the following:
  • filled with a liquid, e.g. water
  • plug closed without changing the pressure from atmospheric and temperature unchanged
  • vertical on a flat floor, in air (not 100 m under water).
(a)
In that case there still is no point asking for the force inside the barrel. What you probably mean is the absolute value of force difference between the inside and outside integrated over the entire area of the barrel material. Which, as you say, can be obtained by integrating ##\ P \cdot dA \ ##.
In the situation I described the contribution from the force on the lid is zero (atmospheric inside and outside). The bottom also (normal force offsets weight of barrel plus liquid) .
(b)
what about it ? Everywhere where there is liquid you expect ## P = \rho g h## + 1 atm, where ##h## is the height of the liquid above the point where you measure.
(c)
In this experiment the 1 atm at the fluid level is replaced by ##\rho g h_2## + 1 atm, where ##h_2## is the height of the liquid in the tube.
And no, I didn't know this experiment had a name and I sure never saw it demonstrated :smile:
You can still do the calculation, just with a different P.
And the barrel will burst sideways, is my bet -- but then again, you want a cylindrical barrel and there the lid/side transition may well be the weakest point. Pascal didn't have oil drums; he had real tuns (barrel-shaped barrels with staves and a lid that tightens itself when pressurized).
##\rho## is the density of the liquid, about 1000 kg/m3 for water.
(a)
(b)
(c)
Ah, i forgot to mention that the barrel is filled with water on a flat foor on sea level, and it is closed.
Well, that is what I made of it. But here at PF you want to be complete in the 'problem description' :smile: -- lots of lengthy threads result because that isn't always the case.
Anyway, does my answer make sense for you ?
The only thing i am confused now is that isn't the water inside the barrel also contributes to the force exerted to the sides of the barrel?
It sure does. "... 1 atm at the fluid level is replaced by ... " so that ##\ P = \rho g (h +h_2 ) ## + 1 atm.
now one last question ( sorry for asking too much)
why did he used the midpoint of the barrels height to calculate the "average pressure" ? shouldn't he just integrated it from the ∫ρgh*2πr*dh all the wayy to the bottom? or would it just yield the same result?
The latter: the pressure varies linearly with height, so the integral is the same as taking height times pressure half way.
thanks so much! i also discovered that the total force after integration will eventually be F = ½ρgh2C
thanks!
9K
  • · Replies 40 ·
  • · Replies 19 ·
19K
