The curl of certain vector fields
hholzer
Given the two vector fields:
<br /> \vec E and \vec B<br />
Where the first is the electric vector field
and the second is the magnetic vector field, we
have the following identity:
<br /> curl(\vec E) = -\frac{\partial \vec B } { \partial t }<br />
and further that:
<br /> curl(curl(\vec E)) = curl(-\frac{\partial \vec B } { \partial t }) <br /> = -\frac{\partial curl(\vec B) } {\partial t }<br />
I tried to prove these by defining the vector fields:
<br /> \vec E = C\frac{ \mathbf e_r } {p^2}<br />
and
<br /> \vec B = &lt;0, 0, B&gt;<br />
where C and B are constants. But I ended up with
zero for curl(E), which cannot be right. So my reasoning
is in error somewhere.
Any insight appreciated.
If p is your radial variable, then the electric field varies only radially and hence has curl zero, so that makes sense. Further, since you have a static magnetic field, its time derivative should also be zero, putting the two equal and satisfying Maxwell's equation.
Hm, then in general how was the result reached that they are equal?
