The Divergence of a Regularized Point Charge Electric Field
The discussion centers on calculating the divergence of the vector field A(𝑟) = 𝑛/(𝑟² + 𝑎²), where 𝑛 = 𝑟/𝑟, representing a regularized electric field of a point charge. The divergence is computed using the formula ∇⋅A = ∂/∂x + ∂/∂y + ∂/∂z, leading to a conclusion that in the limit as 𝑎 approaches 0, the divergence becomes proportional to the δ-function. Participants confirm the approach is correct and emphasize the importance of recognizing the symmetry in the expression to simplify calculations.
  • Understanding of vector calculus, specifically divergence
  • Familiarity with electric field concepts and point charge behavior
  • Knowledge of the Dirac delta function and its properties
  • Proficiency in multivariable calculus, including partial derivatives
  • Study the properties of the Dirac delta function in physics applications
  • Learn about regularization techniques in electromagnetic theory
  • Explore symmetry in vector fields and its implications for simplification
  • Investigate the physical significance of divergence in electric fields
Students and professionals in physics, particularly those focused on electromagnetism, vector calculus, and mathematical physics, will benefit from this discussion.
1missing
1. Problem: Consider vector field A##\left( \vec r \right) = \frac {\vec n} {(r^2+a^2)}## representing the electric field of a point charge, however, regularized by adding a in the denominator. Here ##\vec n = \frac {\vec r} r##. Calculate the divergence of this vector field. Show that in the limit a -> 0 the divergence becomes proportional to the δ-function.
∇⋅ = ## \frac \partial {\partial x} + \frac \partial {\partial y} + \frac \partial {\partial z}##
So it seemed pretty straight forward to me, but I feel like there's something fundamental that I'm not seeing.
##\vec r = \left( x, y, z\right)##
##r = \sqrt {x^2 + y^2 + z^2}##
∇⋅A## \left( \vec r \right) = {\frac \partial {\partial x}} \frac x {\left( x^2 + y^2 + z^2\right)^{1/2} \left( x^2 + y^2 + z^2 + a^2 \right)} + {\frac \partial {\partial y}} \frac y {\left( x^2 + y^2 + z^2\right)^{1/2} \left( x^2 + y^2 + z^2 + a^2 \right)} + {\frac \partial {\partial z}} \frac z {\left( x^2 + y^2 + z^2\right)^{1/2} \left( x^2 + y^2 + z^2 + a^2 \right)} ##
I don't have any trouble with the computation, rather I feel like I didn't set this up correctly. Can anyone confirm if I'm moving in the right direction? Thanks!
What you wrote is completely correct. At first sight, calculating this looks like a lot of work, but once you realize how symmetrical the expression you wrote down is, you can easily conclude that it suffices to calculate one of the three derivatives.
Awesome, guess I'll start plodding away. And I guess just to make sure, for the second part, all I would need to do is set a = 0, integrate over all space, and confirm it equals 1?
