The expected value of the square of the sample mean?
pandaBee
In my notes I keep stumbling upon this equation:
Equation 1: E(X-bar^2) = (σ^2)/n + μ^2
I was wondering why the above equation is true and how it is derived.
E(X-bar^2)
##Summations are from i/j=1 to n
= E[(Σx_i/n)^2)]
= E[(Σx_i/n)(Σx_j/n)]
=(1/n^2)E[(Σx_i)(Σx_j)]
=(1/n^2)ΣΣE(x_i*x_j)
=E(x_1^2) + E( x_2^2 + ... + E(x_n^2)
+ E(x_1*x_2) + E(x_1*x_3) + ... : Equation 2
I'm stuck at this point. Could someone show me how you get to Equation 1 from Equation 2? Assuming that my derivation to Equation 2 is correct.
E(X-bar^2)
= E[(Σx_i/n)^2)]
If you mean
E \overline{X}^2 = \frac{\sigma^2}{n} + \mu
then that cannot possibly be right! For one thing, the "dimensions" don't match. For example, if ##X## is measured in meters, then ##\sigma^2## is measured in ##\text{meters}^2##, while ##\mu## is in meters.
The easiest approach is to recognize that the mean square and variance of any random variable ##Y## are connected by the equation
\text{Var}(Y) = E(Y^2) - (E Y)^2, \; \text{or} \; E(Y^2) = \text{Var}(Y) + (EY)^2
Apply this to ##Y = \bar{X} = \sum X_i / n##. Assuming the ##X_i## are independent and identically distributed there are easy and well-known formulas for ##EY## and ##\text{Var} (Y)## in terms of ##\mu##, ##\sigma## and ##n##. That will tell you the value of ##E \overline{X}^2##.
On the other hand, if you meant that you want to know
E \overline{X^2} = E \sum X_i^2 / n,
then you have a different set of formulas to use. However, you can approach it again using the relationship between mean square and variance.
I think your Equation 1 may contain a slight error, as Ray pointed out
I think the correct equation is E(x-bar)2 = (σ2 / n) + μ2
Yes, you are both correct, the correct equation was actually
The mu had to be squared.
In fact, I can see that I have made a huge blunder in how I was looking at this problem. Thank you both for the insight!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
