What is the relationship between force and velocity in objects in side contact?
  • Thread starter Entanglement
  • Tags
    Force
In summary, the conversation discusses the concept of apparent weight in an elevator and the idea that two objects in side contact moving at the same velocity do not apply a force on each other, unless one object moves at a different velocity. The conversation also mentions the possibility of explaining this in terms of relative kinetic energy and the conditions of a falling elevator within a gravitational field. The conversation also raises questions and clarifications about the application of force in different scenarios.
Entanglement
439
Hey Everyone,
When I was reading about the apparent weight in an elevator I started to think about something. I think If two objects are in side contact moving at the same velocity, neither of them applies a force on the other, because it's as if they were at rest together. A force doesn't arise unless the further objects moves at a less velocity than the other. I guess this is true but I can't explain it to my myself in a proper way. I have the intuition for it but I'm not able to reach a neat explanation. Can it explained in terms of relative kinetic energy? I'm not sure.
If I put a bowling ball on my toe, they are at rest together. But there is most certainly an applied force exerted.
NewtonsFellow said:
Hey Everyone,
If these are the conditions: the elevator is falling within a gravitational field. If the elevator is falling at terminal velocity and the objects are not moving in the elevator, then the objects are falling at terminal velocity as well.
Then you could say: the energy of both objects is kinetic energy, zero potential energy. If one object slows down and is no longer traveling at terminal velocity, then it has transferred some kinetic energy to potential energy.
I think that works.
Yes, I meant both of them are in contact such that neither of them is exerting its weight on the other.
I think that works.
I never meant that these objects are in a moving elevator. I just wanted to create an analogy by imagining that two objects were in side- contact, and I tried to imagine the force that one would act on the other at different conditions.
It's about the sums of all other forces on each object divided by their masses. If those are the same, they can remain at relative rest without a force between them. Ignoring rotation.
NewtonsFellow said:
Hey Everyone,
Do you mean in free fall or some other speed? To go at any speed other than free-fall, there are non-gravity forces at play on both objects. In general, one object might be transferring some force to the other. You say they are side-by-side, so it sounds like you are stating that they are not applying force on each other. Then it is logically wrong to question if there is force between them, when you stated otherwise as an assumption.
That is wrong. Just because they are at the same velocity doesn't mean that one can't be applying a force to keep the other at that velocity.
PS. The case of free-fall is special. You know that gravity alone will make two objects (in a vacuum) accelerate and fall at the same speed. So there is no force between them. If they were at a non-free-fall speed, then you know that there are other forces involved and you don't know if those forces are separately applied to the objects or if one object is applying some force on the other object.
1. What is the force between two objects?
The force between two objects is a physical interaction that causes a change in the motion of the objects. It is a vector quantity, meaning it has both magnitude and direction.
2. How is the force between two objects calculated?
The force between two objects can be calculated using Newton's law of universal gravitation, which states that the force is directly proportional to the product of the masses of the objects and inversely proportional to the square of the distance between them.
3. What factors affect the force between two objects?
The force between two objects is affected by the masses of the objects and the distance between them. The force increases as the masses of the objects increase and decreases as the distance between them increases.
4. Can the force between two objects be negative?
Yes, the force between two objects can be negative. This means that the force is acting in the opposite direction of the motion of the objects. For example, if you push a box to the left, the force of friction between the box and the ground is acting to the right and is considered a negative force.
5. How does the force between two objects change with distance?
The force between two objects decreases as the distance between them increases. This is because the gravitational or electrostatic force weakens as the distance between the objects increases, following the inverse square law.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
