Maximum Compression of a Spring in a Collision?
  • Thread starter Thread starter planck42
    Collision Force
In a perfectly inelastic collision with a wall, an object on a spring compresses the spring to its maximum extent. The discussion highlights the challenge of calculating the force exerted during the collision, noting that traditional methods like Newton's Second Law may not apply directly. Instead, conservation of energy can be utilized, equating the kinetic energy of the moving system to the potential energy stored in the spring at maximum compression. This leads to the equation mv² = kx², allowing for the determination of maximum compression by isolating x. The conversation emphasizes the importance of using physical intuition and energy conservation in solving the problem.
planck42
An object with mass m is being held on a spring in equilibrium position with spring constant k. This system(both the object and the spring) is moving in one direction with a velocity v. The system then collides perfectly inelastically with a wall. What is the maximum compression of the spring?
F=-kx
Conservation of Momentum(?)
Newton's Third Law of Motion
By Newton's Third Law, the force the wall exerts on the system is equivalent in magnitude to the force the system pushes on the wall. However, the force appears incalculable. Newton's Second Law cannot really be used here because it concerns net force on an object. Therefore, it appears that the only way out is to calculate the impulse the object is experiencing and then to take the time derivative of that impulse. This does not seem to accomplish anything either, since the impulse is mv, and when one takes the time derivative of that, it comes out to be ma, which doesn't help my cause one bit. I feel at an impasse with this problem. Help would be much appreciated.
Perhaps we can use some physical intuition to find a relevant equation.
Perfectly inelastic generally means the two objects "stick" together and for most situations means that you can't rely on conservation of energy. However, in this case you could argue that the energy is completely converted into potential energy of the spring and hence we could try using conservation of energy.
With this tool at your hands, the solution is simple.
Ah! I never thought of it that way. So what you're saying is that mv²=kx² since the 1/2's cancel.
Correct. All you need to do is isolate for x then.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
