The fundamental group of the disk is trivial, why?
math8
How do we show that the fundamental group of the disk D^2={(x,y) in RxR: x^2 +y^2< or eq. to 1} is trivial?
I know how to show that the fundamental group of the circle is isomorphic to the group of the integers under addition, but for some reason, I don't see a way to show that the fundamental group of the disk is trivial.
Because the disk is contractible?
Oh yes so there is a contraction and from there we can get a path homotopy that shows that every loop in the disk is path homotopic to the constant loop at the base point. Hence the fundamental group of the disk is trivial.
Thanks
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
