- 37,032
- 16,053
You still have 3 coordinates. None of what you wrote in the OP involved adding extra coordinates to the manifold.
Anamitra said:[tex]{ds}^{2}{=}{R}^{2}{[}{(}\frac{xdy-ydx}{{x}^{2}{+}{y}^{2}}{)}^{2}{+}\frac{{x}^{2}{+}{y}^{2}}{{R}^{2}}{(}\frac{dz}{\sqrt{{x}^{2}{+}{y}^{2}}}{)}^{2}{]}[/tex]
Ben Niehoff said:In addition, it is not of the form
[tex]ds^2 = du^2 + dv^2[/tex]
for any coordinate functions u, v. (Remember, the one-forms [itex]du, \ dv[/itex] should be closed, i.e. [itex]ddu = 0[/itex] and [itex]ddv = 0[/itex]).
Anamitra said:Consider the metric:
[tex]{ds}^{2}{=}{dx}^{2}{+}{dz}^{2}[/tex]
Transformations:
[tex]{z}{=}{R}{[}{1}{-}{cos}{\theta}{]}[/tex]
And
[tex]{x}{=}{R}{\phi}[/tex]
[tex]{dz}{=}{R}{sin}{\theta}{d}{\theta}[/tex]
[tex]{dx}{=}{R}{d}{\phi}[/tex]
[tex]{dx}^{2}{+}{dy}^{2}{=}{R}^{2}{sin}^{2}{\theta}{d}{\theta}^{2}{+}{R}^{2}{d}{\phi}^{2}[/tex]
[tex]{=}{R}^{2}{(}{d}{\phi}^{2}{+}{Sin}^{2}{\theta}{d}{\theta}^{2}{)}[/tex]
Ben Niehoff said:The metric (coordinates re-labeled to avoid confusion with spherical metric)
[tex]ds^2 = R^2 (du^2 + \sin^2 v \; dv^2)[/tex]
is NOT curved, as a relatively quick calculation of its curvature reveals. Try it.
Anamitra said:Take R as a fixed Schwarzschild Radius[coordinate value]
[You may think in parallel transporting a vector round the 45 degree latitude and see if it turns when it comes back to the original point--you will find curved space]
[On the same metric try out the transformations given in post #35]
WannabeNewton said:For that metric it is a rather trivial task to show that [itex]R^{\alpha }_{\beta \mu \nu } = 0[/itex] identically.
I just worked out the curvature. The above metric is flat, not curved. There is one non-zero Christoffel symbol, but no non-zero components to the Riemann curvature tensor. So it is apparently some sort of "polar-like" coordinates in a flat space.Anamitra said:So far as the metric coefficients are concerned it has to represent curved space[Hope v has been used as a variable]
Dickfore said:Would an OP please close this topic? It's excruciating to read this troll.
Ben Niehoff said:OK, I think at this point you will not be convinced unless you actually do a computation. So let's simplify this as much as possible and do just 2 dimensions. Take the following metric for the sphere,
[tex]ds^2 = d\theta^2 + \sin^2 \theta \; d\phi^2,[/tex]
and show us how to obtain a globally flat coordinate system, using your method.
What Dickfore said in post #24Dickfore said:So, please eliminate one of them and express the metric in the form:
[tex] ds^{2} = A(x, y) \, dx^{2} + 2 \, B(x, y) \, dx \, dy + C(x, y) \, dy^{2}[/tex]
This metric (not a sphere) is flat:Anamitra said:In Relation to Post #46
Is DaleSpam ready to confirm that the Schwarzschild sphere[for a fixed coordinate r] is not a curved space?
I have made a claim[through #46] that it represents curved space. The answer from a Science Advisor would be crucial to the issue.
I don't see how the transported vector turns though under the metric [itex]ds^{2} = d\phi ^{2} + sin^{2}(\theta) d\theta ^{2}[/itex]. If for example you choose to parallel transport the vector [itex]\mathbf{v}[/itex] around a circle of latitude [itex]\theta = \theta _{0}[/itex] then you could set up the parametric equation for the circle as [itex]u^{A}(t) = t\delta ^{A}_{1} + \theta _{0}\delta ^{A}_{2}[/itex] and the tangent vector would be [itex]\dot{u^{A}} = \delta ^{A}_{1}[/itex] and the parallel transport of the original vector , [itex]\bigtriangledown _{\dot{\mathbf{u}}}\mathbf{v} = 0[/itex], comes to [itex]\frac{\partial v^{A}}{\partial \phi } + \Gamma ^{A}_{B1}v^{B} = 0[/itex] and since for that metric that christoffel symbol vanishes I just get [itex]\frac{\partial v^{A}}{\partial \phi }= 0[/itex]. If the vector's direction really does change maybe I interpreted the bases wrong; I interpreted them as they are on a 2 - sphere.TrickyDicky said:The paralled-transported vector turns just because you are restricting it explicitly with certain coordinate restricition, if you do a global transformation in the embedding space you may no longer keep on the 2-sphere surface and therefore it doesn't represent the curved space you think it's representing.
