MHB The height of a section of overlapping circles.
The discussion centers on calculating the height (y) of the overlapping section between two identical circles with a radius of one. The circumference of the circles is established as 2π, with the overlapping segment representing 1/6th of this circumference. A right triangle is formed using the center of a circle, the midpoint of the segment y, and a point of intersection, leading to the identification of a 30-60-90 triangle. The relationship between the sides of this triangle and the use of trigonometric functions and the Pythagorean theorem are explored to derive y. Ultimately, the exact value of y is determined to be 2 - √3.
Zekes
Say I have two identical circles, both of radii of one, overlapping, as shown in the diagram below:
In this diagram, x is the circumference of the circles, and the bit of the bottom circle which is drawn blue (the overlapping bit) is 1/6th of the whole circumference.
What I'm looking for is y, which is this:
Now, working out x is easy - it's 2 \pi r, thus the overlapping bit is 1/3 \pi r. But how do I proceed in finding y from here? Help is much appreciated! Thanks!
Mathematics news on Phys.org
Imagine a right triangle from the centre of a circle, the midpoint of the segment y and one of the points of intersection of the circles. This triangle has hypotenuse 1 and side opposite the centre of the circle 1/2. Also, this triangle is 30-60-90. Can you use some basic trig and the Pythagorean theorem to find y?
Although I know of trigonometry and Pythagoras, I don't see how having a point of the triangle at the midpoint of y can help me find the whole of y.
Also using some segment formulas I came up with I plugged in my values to get $$y/2=1(1-\cos ((\pi /3)/2))$$ which gives me a formula $$\approx$$ 0.133975 however this is not exact and I need an exact answer.
$$\frac{y}{2}=1-\cos30=1-\frac{\sqrt3}{2}=\frac{2-\sqrt3}{2}\implies y=2-\sqrt3$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
