Is the Matrix Notation for Partial Derivatives Useful?
Cyrus
A couple of quickies on the interpertation of the partial derivative I want to clear up with myself.
If we have a parametric function:
r(u,v)= x(u,v)i + y(u,v)j+z(u,v)k
then the partial derivative W.R.T u or v is regarded as the tangent vector, and we can think of it as the speed, or velocity vector at the point (u,v) along the curve.
Now for a function defined by,
xi + yj + z=f(x,y)k
When we take the partial derivative with respect to x or y, can we still regard it as the speed or velocty vector at the point (x,y)?
I don't see any reason not to call it that, they are both legitamite vectors tangent at the point (x,y) or (u,v).
xi + yj + z=f(x,y)k
What does this mean?
x\widehat i + y\widehat j + z = f(x,y)\widehat k
I have no trouble conceiving of r(u,v) as a position vector represented in an orthogonal basis (\widehat i, \widehat j, \widehat k) and the partial derivatives being "velocity" relative to a single changing parameter (a.k.a. u = "time" with constant v), but if you take the partial wrt x at constant y,z of your equation you get
\widehat i = \frac{\partial f(x,y)}{\partial x}\widehat k
which is a fundamental violation of everything we know about orthogonal vectors. Did you mean
z(x, y) = -x\widehat i - y\widehat j + f(x,y)\widehat k
with z being some vector function of x,y?
Sorry for being unclear, I meant that the the z component was a function of x and y, basically, f(x,y)k . I don't see why you put a negative sign infront of x and y though.
Any help would be appreciated.
maybe you could restate the second equation that you'd like help with? I agree with OlderDan with regards to everything else.
If you clarify the last part of your post, perhaps we could help more.
Ok, let's try this again from the top;
Now for a surface defined by,
x i + yj + f(x,y)k
The tangent vector would be,
1i + 0j + f_x(x,y) k <---(Can this not be considered the speed as well?)
Your surface: x i + y j + f(x,y) k exists in R^3, the way you have written it is equivalent to writing it as
f(x,y)k = -x i - y j, or omitting the k unit vector (as it is assumed)
f(x,y) = - x i - y j. Note x and y are both independant variables. The partials are
f_x(x,y) = -1. f_y(x,y) = -1
That is my understanding of your question. For z(x,y) to be an independant variable, you would need a function f(x,y,z) in order to represent it's partials.
x i + yj + f(x,y)k
Correct.
Let us parametrize a surface S in the following manner:
\vec{S}(x,y)=x\vec{i}+y\vec{j}+f(x,y)\vec{k}
then the tangent vectors are given by:
\frac{\partial\vec{S}}{\partial{x}}=\vec{i}+\frac{\partial{f}}{\partial{x}}\vec{k}
\frac{\partial\vec{S}}{\partial{y}}=\vec{j}+\frac{\partial{f}}{\partial{y}}\vec{k}
Im sorry, but I have to disagree. A vector is not equal to its k component that you can move around and set equal to like that whozum. Its not an equation, its a vector, with meerely functions as components.
To arildno, can we regard it as the "speed" like we do for parametric surfaces? I.e. is the "speed" W.R.T x always 1 in the i direction, and f_x(x,y) in the z dierction? Likewisee the speed W.R.T y, always 1 in the y dirction, 0 in the x direction, and f_y(x,y) in the z direction?
Or is there something fundamentally wrong to call it the "speed"
Why call it speed??
Why muddle the issue in that manner; the concept of tangent vectors is good enough, isn't it?
Because I want to know if calling something "speed" is reserved for a special condition on the derivative, or can we call this situation speed as well. I want to have a rigerious definition of when and were speed can be used to describe a derivative.
Im sorry if I seem anal about it, but I want to be very precise in when and where I can call it the speed. The book calles the partial of a parametric function the speed, but it does not call a function in terms of x,y the speed, which is why I ask about the rigidity (is that a word?) of the use of the term speed.
I have read the conversation that follow this post of yours, but I want to go back here to respond to this, and make some additional observations. If you have not discovered the answer yourself, the negative signs are there because I moved those terms to the other side of the equation to solve it for what you had called z. The equation only made sense if z is a vector function of x and y.
By changing your statement to say
x i + yj + f(x,y)k
you have changed from an equation to an expression. That expression can be interpreted as defining a surface in three dimensional space. arildno reasonably turned your expression into an equation with S as a vector equivalent to your expression. I assume S was chosen because your expression represents a set of termination points of vectors from the origin to the surface defined by the function f(x,y). By making this equality as a reasonable way to represent your expression, a sensible way of representing the partial derivatives with respect to x and y is achieved.
But notice what has been done here. Your "new" problem has been mapped into your "old" problem with S in place of r, x in place of u, y in place of v, and f(x,y) in place of z(u,v).
\vec{r}(u,v)=x(u,v)\widehat{i}+y(u,v)\widehat{j}+z(u,v)\widehat{k}
\vec{S}(x,y)=x(x,y)\widehat{i}+y(x,y)\widehat{j}+f(x,y)\widehat{k}
This is nothing more than a special case of your more general starting equation, with the x and y coordinates being functions of only one of the two parameters. What holds in the general case will hold in any specific case. If you want to think of the parameter x as "time" then the special case becomes
\vec{S}(t,y)=t\widehat{i}+y\widehat{j}+f(t,y)\widehat{k}
and
\frac{\partial\vec{S}}{\partial{t}}=\widehat{i}+\frac{ \partial{f}}{\partial{t}}\widehat{k}
and sure enough, this is a "velocity" relative to the time parameter with the y parameter held constant. You could do the same thing wrt y instead of x. In this special case, what you have shown is that "velocity" wrt to one of the two parameters is always perpendicular to either the x-axis or the y axis
As arildno has noted, there is really nothing to be gained by thinking in terms of velocity, but it does fit with your general construct. When the parameters are the spatial variables x and y, a change dx with y held constant is equivalent to moving a distance dx along the surface in the x direction, and a distance \frac{ \partial{f(x,y)}}{\partial{x}}dx in the z direction. The partial derivative is the rate of change of the vector S with respect to a change in the spatial variable x. If you want to think of x as "time" than it is also a velocity.
Thanks! I was considering that but I wanted to wait for one of your guys anwsers. That helps me alot.
Ok, another question on interpretations of partial derivatives. It shows in the text that one way of thinking about the partial derivative W.R.T x or y is the slope of the tangent vector.
But as you two have pointed out, this vector is:
\frac{\partial \vec{S}}{\partial{x}}=\widehat{i}+\frac{ \partial{f}}{\partial{x}}\widehat{k}
So If we look at this vector, it has only components in the i and k direction. So in this SPECIAL case, we can see that the slope is the rise in z over the run in x, or f_X(x,y)/ 1, so we see that the partial of z is the slope of the tangent line.
But this is true only because the y component is zero. If the y component were not zero, it would be meaningless to mention the word slope. Is this reasoning correct?
The situation you are now looking at is that of a vector pointing to a location on the surface. That vector will always have the form
\vec{S}(x,y)=x\widehat{i}+y\widehat{j}+f(x,y)\widehat{k}
One of the most important things about partial derivatives is keeping track of what is being held constant. In your case, taking a partial with respect to x means that y is being held constant, and taking the partial with respect to y means that x is being held constant. If you combine the two you can write the differential
d\vec{S}(x,y) = \frac{\partial{\vec{S}(x,y)}}{\partial{x}}dx + \frac{\partial{\vec{S}(x,y)}}{\partial{y}}dy = \left[\widehat{i} + \frac{ \partial{f}}{\partial{x}}\widehat{k}\right]dx + \left[\widehat{j} + \frac{ \partial{f}}{\partial{y}}\widehat{k}\right]dy = dx\widehat{i} + dy\widehat{j}+\left[\frac{\partial{f}}{\partial{x}}dx + \frac{\partial{f}}{\partial{y}}dy\right]\widehat{k}
What does this mean? Imagine yourself at the point on the surface (x, y, z=f(x,y)). Now you want to move to another point on the surface. The path you take is quite arbitrary, as long as you wind up where you want to go. You can walk along the surface, or you can walk in the x direction some distance, then walk in the y direction some distance, then look "up" and "down" (z direction) to see if you need to climb up to or down to get back to the surface. The differential vector d\vec{S} tells you the components of the vector pointing from \vec{S} to \vec{S} + d\vec{S}, both of which terminate on the surface. The distance you have to move in the z direction is the sum of the changes in the z coordinate of the surface resulting from the displacements dx and dy. If your path to the new location only requires you to move in the x direction, then in the z direction it is because dy has been chosen to be zero. If your path to the new location only requires you to move in the y direction, then in the z direction it is because dx has been chosen to be zero. It is simply a matter of the (x,y) coordinates of your destination relative to your starting point.
And notice what happens if you divide the differential displacement by the time dt it takes you to move. You get the velocity of the motion
\frac{d\vec{S}(x,y)}{dt} = \vec{v} = \frac{dx}{dt}\widehat{i} + \frac{dy}{dt}\widehat{j}+\left[\frac{\partial{f}}{\partial{x}}\frac{dx}{dt} + \frac{\partial{f}}{\partial{y}}\frac{dy}{dt}\right]\widehat{k}
Wow that is a neat trick. Could you explain how you arrived at your 3rd equation. Where did you get ds= ds/dx dx + ds/dy dy from?
Hey Dan, a quickie. It seems that in this line you are using the tangent plane approximation to write:
but you wrote it in vector form instead of scalar form. I have not seen that done before, could you please expand upon how that is correct?
It makes sense to me, a more direct way would be to use the direct linearization for the scalar function. And that's obviously the z component. And that's associated with a displacement of dx in the i direction and dy in the j direction, so you can't intuit how you came to the formula. Its your notation that I have not seen before, i.e chanigng a scalar formula into a vector formula like that.
Hello, are you there dan. lol :-)
This comes from fundamental properties of differentials of multivariate functions. By definition of a function, an arbitrary function in 3-space, f(x, y, z), must have a unique value at any coordinate point (x, y, z). The change in f corresponding to changes in x, y and z is
\Delta f(x, y, z) = f(x + \Delta x, y + \Delta y, z + \Delta z) - f(x, y, z)
If you hold y and z constant, this becomes
\Delta f(x, y, z) = f(x + \Delta x, y, z) - f(x, y, z)
If you divide by \Delta x and take the limit as \Delta x approaches zero you have
\frac{df(x, y, z)}{dx} = \mathop {\lim }\limits_{\Delta x \to 0} \frac{f(x + \Delta x, y, z) - f(x, y, z)}{\Delta x} = \frac{\partial f}{\partial x}
df(x, y, z) = \frac{\partial f}{\partial x} dx
Changing only y and changing only z yields similar equations in those variables. The justification for adding these results to get the total differential is that the change in the function when moving a differential distance from one point in space to another must be path independent. So if I move a small distance dx, followed by a small distance dy, followed by a small distance dz, or make those same changes in position in any other order, the sum of the changes in f must always be the same, and that must be the same as making all three changes at the same time. Putting it together you have
df(x, y, z) = \frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy + \frac{\partial f}{\partial z} dz
where in each term the partial derivative implies that the other two variables are being held constant. Always remember that a partial derivative implies something is being held constant, and it is very important to know what that is.
That is not a very formal derivation, but the most rigorous derivation will lead to the same result. In your problem you have a surface defined by the function of two variables z = f(x, y). By application of the above to a function of two variables you have
dz = df(x, y) = \frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy
Notice that in this case the partial derivatives imply only one other variable is being held constant, not two, because z is constrained to have only one specific value at every coordinate point (x, y) rather than being allowed to vary independently. dz is thus uniquely determined by the function f(x, y) and the changes dx and dy.
The vector introduced by arildno
is just another way to describe the surface defined by f(x, y). Think of it as a sum of two vectors, one from the origin to the point (x, y) in the x-y plane and then a vertical vector from the x-y plane to the surface. To move to a new position on the surface, you must move to a new coordinate (x + dx, y + dy) and then move a distance dz = df(x, y) to get back to the surface. You can draw a differential vector from the initial point to the final point. That vector is the change in the vector to the surface from one point to the next. If z could change arbitrarily, moving from one point to another in 3-space would be
d\vec{S} = dx \widehat{i} + dy \widehat{j} + dz \widehat{k}
but z cannot change arbitrarily because the S vector must terminate on the surface. Since z is a function of x and y, the vector S is a function of x and y and this becomes
d\vec{S}(x,y) = dx \widehat{i} + dy \widehat{j} + df(x, y) \widehat{k}
d\vec{S}(x,y) = dx \widehat{i} + dy \widehat{j} + \left[\frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy \right] \widehat{k}
If x and y are functions of time, or some other parameter t, then by the chain rule you have
\frac{d\vec{S}(x,y)}{dt} = \vec{v} = \frac{dx}{dt}\widehat{i} + \frac{dy}{dt}\widehat{j}+\left[\frac{\partial{f}}{\partial{x}}\frac{dx}{dt} + \frac{\partial{f}}{\partial{y}}\frac{dy}{dt}\right ]\widehat{k}
The identical result is obtained by taking the derivative wrt to t of the defining equation for the S vector in terms of partial derivatives wrt x and y as done in the previous post.
I hope the previous post has made this connection for you. The vector S from the origin to a point on the surface corresponding to the coordinate point (x, y) is just another way of describing the surface, equivalent to the function z = f(x, y). If this is not clear, we can follow up later.
I am confused at this line:
Why did you write the partial as a differential? I've never seen a partial expressed as a differential in that way before. Is that "mathematically legal"? Is it possible to edit your post so that it conforms to a proof that is STRICT within the mathematical rules, not to be rude, but I like to see rigid proofs becuase I need to build my skills.
But If you remember, I had a post on the chain rule a while ago. If all I need is a rigid proof on the chain rule, I *hopefully* mastered that theory, somewhat :-)
It seems to me for what your doing, I just need to use the chain rule for the z component, and becuase that depends on dx and dy, I can use dx for the i component and dy for the j component, and I arrive at your anwser much more directly. Is this method ok?
HAAAAAA HAAAAAAAAA, brought back from the dead.
Would you care to explain your notation please dan,
I have not found in any of my math books a ds of a vector function before. I have seen partial derivatives of vector functions, but never, what appears to be your case, the total derivative?
It is just what it looks like -- a vector whose components are differential forms.
In fact, if you like to think of vectors being "column vectors" and differential forms as being "row vectors", then dS is a matrix!
Note that dS i is simply a directional derivative... in particular, the partial derivative with respect to x. Using Dan's notation, we feed i to each of the differential forms... dx spits out a 1, and dy spits out a 0, and we get the partial derivative of S with respect to x.
Could you elaborate on how its a matrix please, are you taking about doting the vector with the del vector? I find it sad that I could not find this notation in any of the 4 different calclus books I have. Tisk, tisk tisk...
The equation only makes sense in the context in which it was first written. It was an attempt to give you feel for why the total differential of a function is the sum of products of its partial derivatives times the differentials of the independent variables of that function. The equation was intended to demonstrate that if you vary only one of the independent variables, the total differential of the function has to be the partial derivative wrt that one variable times the differential of that one variable. Whan the equation was presented, it was cleary stated that y and z were being held constant. Since a similar result must hold when varying only one of each of the independent variables, a sum of similar terms is the most likely form for the total differential. The next question would be, what else could the total differential look like? I can't think of any alternatives.
If you want a more rigorous mathematical treatment, then I suggest you get a good textbook on multivatiate calculus and dig into it. My recollection, which certainly could be faulty, is that most books simply state it with no more proof than what I gave. Surely you have seen the statement
df(x, y, z)} = \frac{\partial f}{\partial x}dx + \frac{\partial f}{\partial y}dy + \frac{\partial f}{\partial z}dz
in those books you looked at. You simply need to develop some sense for the implications of changing a function by changing one input variable at a time, and then generalize to arbitrary differential changes in all the input variables. That's all that this equation represents.
I really do not follow the connection you are making to the chain rule. This expression for the total differential is not about composition of functions, where the chain rule applies. It is about identifying the separate contributions to the total differential from the differentials of the independent variables. The chain rule certainly comes into play when you have functions of functions, such as in the case of parametric equations for example, but that's another layer on this fundamental representation of the total differential of a function of multiple variables.
I think we may be losing track of what led up to this equation. It is not an equation for some arbitrary vector function of (x, y, z). It is a function that you introduced long ago when you wrote the expression
xi + yj+f(x,y)k
Others contributed the "hat" notation to clearly identify the orthogonal unit vectors, and introduced the S to turn the expression into the equivalence
The long equation you have cited is specific to the class of functions represented by this equation. It does not apply to every conceivable vector function. The vector S represented by this equation is a position vector from the origin to a point on a surface in 3-space defined by the functional relationship
z = f(x,y)
Part of what you cited is of the form
d\vec{V}(x,y) = \frac{\partial{\vec{V}(x,y)}}{\partial{x}}dx + \frac{\partial{\vec{V}(x,y)}}{\partial{y}}dy
This is completely general for any vector function (V) of the variables x and y and could apply to vectors in 2 dimensions or 3 dimensions. This equation, and its analogous form for a vector function of three variables
d\vec{V}(x,y,z) = \frac{\partial{\vec{V}(x,y,z)}}{\partial{x}}dx + \frac{\partial{\vec{V}(x,y,z)}}{\partial{y}}dy + \frac{\partial{\vec{V}(x,y,z)}}{\partial{z}}dz
should be found in any good reference on vector analysis. I can believe you have not seen what came after this for the function S(x,y), namely
d\vec{S}(x,y) = \left[\widehat{i} + \frac{ \partial{f}}{\partial{x}}\widehat{k}\right]dx + \left[\widehat{j} + \frac{ \partial{f}}{\partial{y}}\widehat{k}\right]dy = dx\widehat{i} + dy\widehat{j}+\left[\frac{\partial{f}}{\partial{x}}dx + \frac{\partial{f}}{\partial{y}}dy\right]\widehat{k}
because that is not general; it is a specific application of the general form to the class of functions (position vectors to points on a surface defined by f(x,y)) you introduced with your original expression.
There is nothing unique or mysterious about this. The notation is customary notation often used in physics to represent vector functions in 3-space. In this case, the differential change in vector S is just a vector of infinitessimal length pointing from one point on the surface to a nearby point. The vectors from the origin to those two points would be \vec{S} and \vec{S} + d\vec{S} respectively.
Just another way to represent vectors
<br /> \begin{array}{l}<br /> S = \left[ {\begin{array}{*{20}c}<br /> x \\<br /> y \\<br /> {f(x,y)} \\<br /> \end{array}} \right]
<br /> dS = \left[ {\begin{array}{*{20}c}<br /> {dS_x } \\<br /> {dS_y } \\<br /> {dS_z } \\<br /> \end{array}} \right] = \left[ {\begin{array}{*{20}c}<br /> {\frac{{\partial S_x }}{{\partial x}}dx + \frac{{\partial S_x }}{{\partial y}}dy} \\<br /> {\frac{{\partial S_y }}{{\partial x}}dx + \frac{{\partial S_y }}{{\partial y}}dy} \\<br /> {\frac{{\partial S_z }}{{\partial x}}dx + \frac{{\partial S_z }}{{\partial y}}dy} \\<br /> \end{array}} \right] = \left[ {\begin{array}{*{20}c}<br /> {dx} \\<br /> {dy} \\<br /> {\frac{{\partial f}}{{\partial x}}dx + \frac{{\partial f}}{{\partial y}}dy} \\<br /> \end{array}} \right] \\ <br /> \end{array}<br />
