Is Infinity Plausible in the Universe?
  • Thread starter Thread starter Lightning-Rod
    Infinity
The discussion centers on the concept of infinity in relation to the universe's mass and density. It argues that since the universe has a finite density, it logically follows that both its mass and size cannot be infinite. The reasoning suggests that if mass were infinite, it would fill the universe completely, which contradicts the idea of a finite density. Additionally, the conversation highlights the paradox of infinite space versus finite mass, emphasizing that infinities often lead to nonsensical conclusions. Overall, the thread explores the implications of these ideas on our understanding of the universe.
Lightning-Rod
Hello. The word "infinity" often comes up in physics, but observational evidence seems to preclude any form of infinity whatsoever: either everything must be infinite, or nothing can be infinite.
My line of thought comes from the fact that the density of our universe is not infinite. Therefore, the mass of our universe cannot be infinite either. Then, the size of the universe cannot be infinite either, since it's been growing ever since the beginning of time and you can't grow from "infinite" to "more-than-infinite", can you?
Indeed, even numbers themselves would be finite: if you made each and every elementary particle in the universe represent one bit of information, there would still be an upper limit to the numbers that could be represented by such a computing system. Since no higher numbers could possibly exist in the universe, it effectively makes numbers finite.
Is my reasoning correct or flawed?
Why does it follow that if the universe doesn't have infinite density that it doesn't have infinite mass?
If the universe is infinite in spatial extent and contains infinite mass that says nothing about what the density should be.
Because if mass were infinite, you would have enough of it to fill every nook and cranny of the universe, no matter how big the universe was. Otherwise, it would mean that mass is "less infinite" than space.
Could you describe the density of states in conventional superconductivity, please? And try to do that without invoking any "infinity" at the superconducting gap edge.
If you can't do that, move on to the van Hove singularity that's present in the phonon density of states of the common materials that you use in your modern electronics.
Zz.
and the same argument can go the other way - if the universe were infinite in size, you could always spread the mass around thinner and thinner no matter how much mass there was.
See why infinities usually don't make any sense?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
21K
16K
