The tension in the horizontal bar connecting the two halves of the ladder
  • Thread starter Thread starter soccergenious
    Horizontal Tension
The discussion focuses on calculating the tension in the horizontal bar of a stepladder, along with the normal forces at points A and B, and the reaction force at hinge C. The ladder is treated as a single object, with the painter's weight affecting the calculations. It is noted that the normal forces at A and B must sum to 617.4 N. To find the tension in the horizontal bar, moments can be taken about the top hinge, which also helps determine the horizontal reaction force at hinge C. Understanding these forces is crucial for solving the problem accurately.
soccergenious
A stepladder of negligible weight is constructed where x = 1.80 m. A painter of mass 63.0 kg stands on the ladder 3.00 m from the bottom.
Assuming the floor is frictionless, find the following. (Suggestion: Treat the ladder as a single object, but also each half of the ladder separately.)
(a) the tension in the horizontal bar connecting the two halves of the ladder
N
(b) the normal forces at A and B
N (at A)
N (at B)
(c) the components of the reaction force at the single hinge C that the left half of the ladder exerts on the right half
N (rightward component)
N (upward component)
I do not know how to start this problem but i know that for (b) both forces should add up to 617.4
If you take moments about the top hinge (for half the ladder), you can determine the tension in the center bar. Once you know that, you can get the horizontal reaction force on the top hinge.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
