Unit of Momentum | What is the Unit of Momentum?
  • Thread starter Thread starter Rasine
    Momentum Unit
The unit of momentum is defined as kg*m/s, derived from the formula p=mv. While there isn't a specific unit of momentum named after a scientist, it can also be expressed in Newton-seconds (N*s), since a Newton equals 1 kg*m/s². This alternative representation effectively cancels one of the seconds in the original unit, although some find it unnecessary. Despite its perceived lack of practicality, N*s is recognized and used in certain contexts. The discussion highlights the flexibility in expressing momentum while emphasizing the standard unit.
Rasine
what is the unit of momentum?
i know that p=mv which has units of kg*m/s but is there another way to write it?
AFAIK, there isn't a unit for momentum named after a famous scientist, if that's the kind you're asking for - (like Energy = Kgm^2/s^2 = Joule).
is there a way to write it using Newtons?
A Newton is equal to 1 kg*m/s^2
So I guess theoretically you could give momentum in Newton seconds (as this would effectively cancel one of the "seconds"), but that seems pointless to me.
although it does seem pointless, I've seen it used and I believe N*s is acceptable
I'll be damned. Interesting
http://en.wikipedia.org/wiki/Newton-second"
