What Is the Importance of Curl in Understanding Vector Fields?
The discussion revolves around the concept of curl in vector calculus, particularly its significance in understanding vector fields and its relationship with various theorems such as the divergence theorem, Green's theorem, and Stokes' theorem. Participants explore the nature of curl as a vector quantity and its implications in calculations and physical interpretations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants raise questions about the necessity of interchanging types of integrals for calculations, the reasoning behind curl being a vector quantity, and the implications of irrotational fields being nonconservative. Further inquiries delve into the conceptual understanding of summing curls and the definition of curl at a single point versus macroscopic circulation.
Some participants provide insights into the utility of integral interchanges for convenience in calculations. Others engage in clarifying the importance of direction in curl and its representation in vector form. Multiple interpretations of the questions are being explored, with no explicit consensus reached yet.
Participants express a sense of urgency in resolving their questions, indicating a homework context that may impose constraints on their understanding and exploration of these concepts.
Urmi Roy
I realize by now I must be making everyone crazy on this forum with my questions on vector calculus...but I really have no choice!
Please bear with me for another few days...I promise I'll get this done as fast and as painlessly as possible.
Here goes...
1.In divergence theorem,green's theorem and stoke's theorem,we basically interchange between types of integrals-e.g green's theorem let's us interconvert line integrals and surface integrals...do we need to interchange between types of integrals just to aid calculations?
2.Why does curl need to be a vector quantity? The concept curl(i.e the amount of rotation at a particular point) could be explained by a scalar quantity also...we wouldn't need to assign a direction?
3. Why is an irrotational field nonconservative?
(I found a website describing an irrotational field as one in which there is 'free energy'...what's this all about?)
As per your first question, yes it does aid in calculations. The integrals you originally use can be done perfectly well, but it is typically far more convenient to do the simpler integral. It could also make identifications easier.. not that I have any examples off the top of my head.
For your second question, you DO want to know in what direction something curls though. It's like assigning a velocity to a scalar. You DO want to know what direction the certain velocity is in, thus we use vectors.
I like your example about assigning a direction to speed.
Thanks.
I promise I don't have many more questions to ask.
But here's another few..
1.The direction of curl is (as a convention ) along the direction prescribed by the right hand thumb rule...now,inside a closed curve,when we sum the curl vector (which is basically the limit of path integral around a point,per unit area around the point; as area tends to zero)the sum of all these path integrals is supposed to be equal to the path integral all around the actual (macroscopic) closed curve(by green's theorem).
My question is: by summing the curls at each point,we are summing the perpendicular vectors representing the curls...but conceptually,how can the sum of these perpendicular vectors represent the macroscopic path integral?
2. Why is curl defined at a single point(as I defined in the previous question)...wouldn't it have been more useful if curl had been the macroscopic circulation instead of the microscopic circulation(as in the total path integral around the entire closed curve)?
3. Lastly,curl may also be defined as the measure of change of a vector field in a direction perpendicular to it...but this definition is not 'visible' in the usual delta formulation of it...please explain if I'm wrong somewhere.
  • · Replies 21 ·
