Thermal Conductivity Homework Statement: Solving for Steady State Heat Flow
AirForceOne
Rod of cross sectional area A and length l has its left end held at constant temperature t1 and its right end held at t2<t1. If the conductivity varies with distance from the left end, x, according to the relationship k= x/R + k0 (R and k0 are positive), what is the steady state heat flow, H, through the rod.
heat flow = kA*((t1-t2)/l)
I've always had a hard time understanding what to integrate and what to take the derivative of. As far as I know, I need to integrate k from some x to some final x...
Consider a small element dx on the rod, corresponding to a change dT in temperature. Temperature T is a function of position x. We have:
H=\frac{dQ}{dt}=kA\frac{dT}{dx}=A(k_o+\frac{x}{R})\frac{dT}{dx}
Therefore: \int^{T_2}_{T_1}AdT = \int^{L}_{0}H\frac{dx}{k_o +\frac{x}{R}}
Now as H is constant, the above integrals can be solved, right? Then you can deduce H from that.
Thanks a ton!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
