Thermal Equilibrium of Hot Iron & Water
A hot iron nail at 800 K is placed in 1.0 kg of water at 25°C, and the goal is to find the final temperature at thermal equilibrium. The heat lost by the nail equals the heat gained by the water, leading to the equation 0.15*450*(800-T)=1*4138*(T-25). The initial calculation mistakenly included an incorrect temperature adjustment, resulting in a negative value for T. After correcting the equation, the final temperature is determined to be approximately 33.06°C. This solution highlights the importance of proper temperature reference points in thermal equilibrium calculations.
TT0
A hot (800 K) iron nail of mass 150 g is placed into a 1.0 kg of water at 25°C. What is the common temperature of the 2 objects once they have reached thermal equilibrium? Assume no change of state of the water.
Heat capacity of iron nail is 450 J/kg/K
Heat capacity of water is 4138 J/kg/K
Q=mc∆T
Q lost in nail=Q gained in water
let T = final temperature
0.15*450*(800-T)=1*4138*(T+25+273)
T=-280.38 K
I don't know why it is negative. Can someone explain what I did wrong?
(T+25+273) should be a difference between the final temperature and initial temp.
Likes TT0
I see thanks!
Is the answer 33.06 C?
Seems reasonable
Likes TT0
Thanks again!
