Thermal expansion of lead sphere
A lead sphere has a diameter 0.05% larger than a steel ring at 70.0 °C, preventing the ring from slipping over the sphere. The discussion focuses on calculating the temperature at which the two diameters will equalize, utilizing the coefficient of linear expansion for both materials. Participants suggest setting up equations for the diameters as functions of temperature change and solving for the required temperature difference. There is a debate about whether to consider volume expansion for the sphere, but it is concluded that linear expansion suffices for this problem. The conversation ends with a clarification on the appropriateness of using linear expansion alone for calculating the dimensions.
craigfc
Hi guys and girls,
I've been going thorugh some problems in cutnell & johnson on heat and temperature and I have become stuck on this question. Can anybody help with this? Its from Cutnell and Johnson 5th p375 Q18*.
A lead sphere has a diatmeter that is 0.05% larger than the inner diameter of a steel ring when each has a temperature of 70.0 oC. Thus, the ring will not slip over the sphere. At what common temperature will the ring just slip over the sphere?
Cheers, any help is much appreciated.
Craig
Consider the coefficient of linear expansion of each material: \Delta L = \alpha \Delta T L_0. What \Delta T is required to make the diameters equal?
OK, I have tried, but my maths is not very good. Can you give me a hint please? So far I have got the same point but I am not sure how to work the equations.
Thanks
Here's a hint: Call the diameter (at 70 degrees) of the steel ring D; then the diameter of the lead sphere is 1.0005 D. Now find the diameter of the steel ring as a function of \Delta T:
D_s = D + \Delta L = D + \alpha_s \Delta T D
Now write a similar equation for the diameter of the lead sphere. Set them equal and solve for \Delta T.
ok, so
L_L= diameter of lead at new temp
L_S= diatmeter of steel at new temp
at 70^oC L_o_L=1.0005L_o_S
so at the new temp,
L_S=L_o_S+ \Delta L_S =L_o_S+ \alpha_SL_o_S \Delta T
and
L_L=L_o_L+ \Delta L_L =L_o_L+ \alpha_LL_o_L \Delta T
and we want L_S=L_L
so
L_S=L_L
L_o_S+ \alpha_SL_o_S \Delta T=L_o_L+ \alpha_LL_o_L \Delta T
since
L_o_L=1.0005L_o_S
then
L_o_S+ \alpha_SL_o_S \Delta T=1.0005L_o_S+ \alpha_L1.0005L_o_S \Delta T
ok, bit stuck now, am I on the write track? if so what do i do next?
Now you want to cancel out whatever you can, like your L_os, substitute in the co-efficients of Linear thermal expansion, and solve for Delta T, after that you should be able to find what temp they mesh well together...;)
ok thanks guys i have sovled that one,
BUT i have another question.
how do you work out the relative proportions of an alloy if you are given the co-efficient of that alloy?
cheers
C.
Hello,
I agree with the finding of the new diameter of the steal ring with the following formula for lenear expansion.
However, inorder to find the new diameter of the lead sphere I think one need to consider the volume expansion of the sphere.
V_L=V_o_L+ \Delta V_L =V_o_L+ \beta_LV_o_L \Delta T
Then find L_L using
V_L=\frac{4}{3} \pi (\frac{L_L}{2})^3
Gamma.
No. All linear dimensions (such as diameter) will expand per the linear expansion coefficient.
Dr. Al,
Let's find the change in radius in both ways.
Say the initial and final radii of a sphere is ,r_1 and ,r_2 respec.
Linear expansion gives,
r_2=r_1(1+ \alpha\Delta T) ---(1)
Considering the volume expansion (assuming a uniform sphere),
r_2^3=r_1^3(1+ 3\alpha\Delta T)
r_2=r_1(1+ 3\alpha\Delta T)^\frac{1}{3} ----(2)
What am I missing?
Regards,
Gamma.
Right.
This is an approximation. Nothing wrong with it; it's just not needed since all we care about in this problem is the linear dimension.
Do a Taylor series expansion of this. You'll find that:
r_2=r_1(1+ 3\alpha\Delta T)^\frac{1}{3} \approx r_1(1 + \alpha\Delta T)
Sorry, I don't get it.
Why do approximate while there is an exact way? Also, how can we neglect the higher order terms for not small enough \Delta T
:confused:
Gamma
I hope you realize that:
Is itself an approximation that ignores higher order terms!
Also, recognize the circularity of your approach: You start with linear expansion, use that to find volume expansion, then take the cube root to get back to linear expansion: right where you started! :smile: All you need is linear expansion.
Thanks for the clarification...
:approve:
