Thermal Physics: Ice skating temperatures
Good ice skating occurs when the ice beneath the skates melts, which can be estimated using the Clausius-Clapeyron equation. The discussion involves calculating the coldest temperature for effective skating, factoring in the pressure exerted by a 70 kg skater and the latent heat of ice melting. Participants clarify the need for specific volumes of ice and water in the calculations, noting that the pressure exerted is approximately 1.372 x 10^7 kg/m^2. The conclusion suggests that the temperature for optimal skating is around -1.0 degrees Celsius, challenging the common belief that pressure alone causes ice to melt and create a slippery surface. Overall, the topic highlights the complexity of the physics involved in ice skating.
H.fulls
It is said that good ice skating only occurs when the ice below the skates melts. Using the Clausius-Clapeyron equation, estimate the coldest temperature at which good ice skating can occur. (Water expands 9% on freezing, Latent heat of ice melting is 334 kJ/Kg, the contact area is 1mm by 5cm and the skater weighs 70kg, water has a molar mass of 18g)
\frac{dp}{dT} = \frac{L}{T(V_{2}-V_{1})}
or I think rearranged like this
p_{0}-p = \frac{L}{\DeltaV} ln\frac{T_{0}}{T}
I have found the pressure exerted as 1.372 x 10^{7} kg/m^{2}
I realize that we want the ice to be melting.. so 273k at this pressure, so I need to find the temperature at normal room pressure of 101 KPa.
However I don't know what to use for the volume?
p_{0}-p = \frac{L}{\Delta V} ln\frac{T_{0}}{T}
Often, you can get an accurate enough answer without integrating by treating the right hand side of the Claussius-Clapeyron equation as constant over the temperature changes involved. Then you can just write it as
\frac{\Delta p}{\Delta T} ≈ \frac{L}{T(V_{2}-V_{1})}
This looks correct except for how you expressed the units. Pressure is force per unit area, not mass per unit area.
The volumes ##V_1## and ##V_2## are "specific" volumes (i.e., volumes per kg of material). Note that water is odd in that the ##V_1## (for ice) is greater than ##V_2## (for liquid water).
... and the answer comes out around -1.0 degree ??
Agreed ... it is far more complex.
