Thermal Physics: Find d(1/T)/dp & d(V/T)/dH
In summary: Yes! thanks you so much appreciate it heaps. Trying to understand what this question means..i know pV=nRT, do i sub that in enthalpy equation which becomes H=U+nRT?want 1/T(p,H) and V/T(p,H) i really don't know where to start for this question and how to approach it.some hints will be much appreciated;thanks in advance.So what you want is\frac{1}{T}=f(p,H)\hspace{2cm}\frac{V}{T}=F(
billybob5588
[SOLVED] thermal physics
the differential of enthalpy is given by dH=TdS-VdP
Beginning with the above relationship, find the equation for the differential of the entropy and then show that (d(1/T)/dp)|H=(d(V/T)/dH)|p
this is what i got so far...
i rearranged dH=TdS-VdP to make S the subject which gives dS=dH/T+Vdp/T
then since S=S(H,p) and using the definition of the differential of S;
dS=(dS/dH)|p*dH+(dS/dp)|H*dp
i got then 1/T=(dS/dH)|p & V/T=(dS/dp)|H
i don't know what to do next and to how to exactly reach the final term of (d(1/T)/dp)|H=(d(V/T)/dH)|p
please help , kind regards
Welcome to PF billybob,
You're on the right lines and almost there. What do you know about the mixed second partial derivatives of an exact differential?
exactness condition
i know that they are equal, i thought i would end up somewhere along those lines so..
=M(H,p)dH+N(H,p)dp
dM/dp=dN/dH
i see where its getting next bit algebra is getting tricky..
do i cheat and just sub (1/T) for M and and V/T for N?
i don't understand how to show this mathematically nicely
billybob5588 said:
exactness condition
Correct.
billybob5588 said:
=M(H,p)dH+N(H,p)dp
dM/dp=dN/dH
I'm not quite sure what you doing here, but you know that,
[tex]\left(\frac{\partial S}{\partial H}\right)_p =\frac{1}{T}[/tex][tex]\left(\frac{\partial S}{\partial P}\right)_H =\frac{V}{T}[/tex]
And you know that,
[tex]\left[\frac{\partial}{\partial P}\left(\frac{\partial S}{\partial H}\right)_p\right]_H = \left[\frac{\partial}{\partial H}\left(\frac{\partial S}{\partial P}\right)_H\right]_P[/tex]
Can you see what you need to do next (it's a really simple step)?
Hootenanny said:
Correct.
And you know that,
[tex]\left[\frac{\partial}{\partial P}\left(\frac{\partial S}{\partial H}\right)_p\right] = \left[\frac{\partial}{\partial H}\left(\frac{\partial S}{\partial P}\right)_H\right][/tex]
subbing in becames..
(d/dp)(1/T)=(d/dH)(V/T)
i can't see how the |H and |p get switched around
Correct. :approve:
Sorry my bad, I left out the subscripts of what I'm holding constant in my previous post. Does it make more sense now?
Hootenanny said:
Correct. :approve:
going to attempt part (b) of the question ill post here if i having difficulties
thanks again!
thanks again!
Your welcome :smile:
part (b)
now for part (b) of this question
Using the equation of state for an ideal gas and the definition of enthalpy (H=U+pV), express 1/T and V/T as function of p and H and show that the relationship in part (a) is valid for an ideal gas.
trying to understand what this question means..
thanks in advance.
So what you want is
[tex]\frac{1}{T}=f(p,H)\hspace{2cm}\frac{V}{T}=F(p,h)[/tex]
With respect to the definition of the enthalpy, bearing in mind that we are dealing with an ideal gas (no potential energy), can you write U as a function of T?
Hootenanny said:
So what you want is
i thought U=0 like you said above, since its an ideal gas which makes H=pV;
i am sorry i don't understand writing U as a function of T since U is 0;
so V=H/p
pV=nRT => p(H/p)=nRT => T=H/nR
that right?
sorry i am completely puzzled by this
Not quite. U is the internal energy, which roughly speaking is the sum of the potential energies and kinetic energies of the gas. Now as I said previously, since the gas is ideal, there is no potential energy; but there is still kinetic energy. Now, how is the kinetic energy of an ideal gas related to it's temperature? (HINT: Equipartition theorem).
the relationship is;
change is kinetic energy means a change in temperature (proportional to each other).
equipartition theorem = 3/2RT
write U as a function of T is is U=3/2RT or U=C*T (where C is a constant)
so H=U+pV
H=CT+pV
that correct? and then make V/T and 1/T the subject?
so H=U+pV
H=CT+pV
Are you sure it's R? Apart from that it looks good.
its 3/2kT sorry;
ok so rearranging to make 1/T and V/T the subject i get
1/T=1/(H-pV)
V/T=H/TP - 1/P => for this one I am not sure cause V/T is not the clear subject there is a T term in the equation
and now i should plug it into equation in part (a) then solve?
i thank you for your continuing help
billybob5588 said:
its 3/2kT sorry
Better :approve:
billybob5588 said:
1/T=1/(H-pV)
I think your missing a factor of C here.
For this one, I think it would be must easier to use the ideal gas eqaution and simply find V/T as a function of P.
Hootenanny said:
Better :approve:
sorry my algebra is a bit weak
H=kT+pV where pV=nRT
H=kT+nRT
i don't see how this can help
and here probably a lot more worse i know this is wrong but I am trying everything.
H=kT+n^2*R^2*T^2/Vp (i got this from p=nRT/V and V=nRT/p and taking the product of this yeilds n^2*R^2*T^2/Vp)
this is embarassing
maths...
Your second expression need not be a function of H, what I meant was,
[tex]PV = nRT \Rightarrow \frac{V}{T} = \frac{nR}{P}[/tex]
Do you follow?
Do you follow?
yes i understand where u got that from but my partial derivative on RHS is [d(V/T)/dH]|p so i need it in terms of H so i can proceed with the partial and proove they are equal
You're quite right, I forgot that the partial derivative was with respect to H :redface:. So, using the definition of enthalpy and the ideal gas law,
[tex]H = \left(C+nR\right)T \Rightarrow T = \frac{H}{C+nR}[/tex]
And,
Now, you should be able to combine the two and hence form an expression for V/T in terms of P and H.
ok i got it, thanks for your help!
ill bugger off now haha;
No problem, it was a pleasure!:smile:
1. What is thermal physics?
Thermal physics is the branch of physics that deals with the properties of matter at the microscopic level, focusing on the effects of temperature, heat, and energy on the behavior of particles.
2. What is the relationship between temperature and pressure?
The relationship between temperature and pressure is described by the Ideal Gas Law, which states that pressure is directly proportional to temperature when the volume and number of particles are held constant.
3. How do you find d(1/T)/dp?
To find d(1/T)/dp, use the chain rule and the expression for temperature as a function of pressure (T = PV/nR). This will result in d(1/T)/dp = (-1/V)dV/dp.
4. How do you find d(V/T)/dH?
To find d(V/T)/dH, use the chain rule and the expression for temperature as a function of enthalpy (T = H/nCp). This will result in d(V/T)/dH = (1/Cp)dV/dH.
5. How is thermal physics applied in real life?
Thermal physics has many practical applications, such as in the design and operation of heating and cooling systems, thermometers, engines, and refrigerators. It is also used in fields such as materials science, meteorology, and astrophysics.
  • Thermodynamics
